Evap Canister Location - JeepForum.com
post #1 of 4 Old 10-17-2013, 06:06 PM Thread Starter
Pkauf123456
I am getting a PO456 code. I changed the gas cap even though the "old" one was barely over a year old. Reset the code and all was well for about 3 days. I've been reading posts about this code and it sounds like I need to check the lines going to my evap canister for cracks. I can't find the darn canister anywhere. Where should it be on a 2003 TJ Rubicon?
Pkauf123456 is offline
post #2 of 4 Old 10-17-2013, 07:01 PM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
It's in the rear of the passenger side rear fender well. I believe you may have to remove the plastic inner fender well to get to it.
NashvilleTJ is offline
post #3 of 4 Old 10-17-2013, 07:28 PM
joeyk803c
Yes. Rear passenger inner-fender well. Remove the fender lining and you will see it. Its a big PITA.
joeyk803c is offline
post #4 of 4 Old 10-17-2013, 09:07 PM
joe108
Check the rubber hoses in the system real good, don't just look at them and assume they are good. I would probably just change them out to make sure, then go from there.
joe108 is offline
