Error p0132 - JeepForum.com
post #1 of 12 Old 05-28-2009, 03:20 PM Thread Starter
mschviuz
Error p0132
Driving to work this am my jeep hesitated while accelerating and shortly after the cel came on. Had the same problem on way home except the idle became "jumpy" a couple of times at stops. Do I need to replace the o2 sensor in front of cat?
mschviuz is offline
post #2 of 12 Old 05-28-2009, 03:26 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
P0131 (M) 1/1 O2 Sensor Shorted To Ground Oxygen sensor input voltage maintained below normal
operating range.
GOLENJEEPTJ is offline
post #3 of 12 Old 05-28-2009, 05:32 PM Thread Starter
mschviuz
operating range.
So does that mean o2 sensor needs to be replaced?
mschviuz is offline
post #4 of 12 Old 05-28-2009, 05:33 PM
GOLENJEEPTJ
Yep, that's the jist of it.Good luck.
post #5 of 12 Old 05-28-2009, 05:38 PM
kdt1970
P0132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
Symptoms
You will likely not notice any drivability problems.
Causes
A code P0132 may mean that one or more of the following has happened:
  • The oxygen sensor heater circuit is shorted out
  • The wiring to the sensor is broken / frayed (less likely)
Possible Solutions
The simplest thing to do is to reset the code and see if it comes back.
If the code comes back, the problem is more than likely the front Bank 1 oxygen sensor. You will likely wind up replacing it but you should also consider these possible solutions:
  • Check for wiring problems (shorted, frayed wires)
  • Check the voltage of the oxygen sensor
2003 Jeep Rubicon
kdt1970 is offline
post #6 of 12 Old 05-28-2009, 05:52 PM
GOLENJEEPTJ
He only has the one 02 sensor on a 98 manifold.There is no bank 2 sensor.
post #7 of 12 Old 05-28-2009, 05:55 PM
kdt1970
I was only looking for the code directly, and didnt notice the year. Sorry bout that.
2003 Jeep Rubicon
kdt1970 is offline
post #8 of 12 Old 05-28-2009, 06:51 PM Thread Starter
mschviuz
thanks guys. Actually i have two o2 sensors. One behind the cat. Im going to replace the front sensor and i'll let you know if that fixes it
mschviuz is offline
post #9 of 12 Old 05-28-2009, 08:17 PM
GOLENJEEPTJ
Yes, but on the 2000 and above with split exhaust manifolds you have an 02 sensor in each!Upstream and downstream.
post #10 of 12 Old 05-28-2009, 09:07 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Not on my 2000 Sport I don't. Build date of March 2000. 2 piece manifold with the Y pipe and no mini cats. Originally sold in Colorado. I only have two 02 sensors on the whole exhaust system, one before the cat next to the TC and one after...
Knuckelhead is offline
post #11 of 12 Old 05-28-2009, 09:55 PM Thread Starter
mschviuz
cool. Replaced the sensor and it is runnimg great! Thanks for the help guys.
mschviuz is offline
post #12 of 12 Old 08-04-2016, 08:28 AM
Spudboy
My 99 TJ started bucking and missing, then the check engine light came on. It seemed to be a fuel issue - too rich maybe? Code was P0132. I took of the gas cap and put back on. Also added fuel injector cleaner. Runs like a top. I dont think it was the fuel injector cleaner as much as it was letting air into the gas tank.
Spudboy is offline
P0132- where exactly is this o2 sensor? zband TJ Wrangler Technical Forum 4 11-10-2009 11:27 AM
Error 27 choeyreplied TJ Wrangler Technical Forum 1 08-21-2009 10:35 PM
error 25 ErikJordan YJ Wrangler Technical Forum 1 01-09-2007 05:23 PM
no bus error gyrusx TJ Wrangler Technical Forum 2 02-08-2005 12:12 PM
