Error Code P0420 & P0432 - What could it be??? - JeepForum.com
post #1 of 4 Old 03-10-2010, 05:14 PM Thread Starter
jrdewitt
Got a question i'm hoping you guys can help me out with... Check engine light came on with codes 420 & 432 which translate to "Catalyst 1/1 efficiency below required level" & "Catalyst 2/1 efficiency below required level" respectively. Thought I figured it out when i noticed a broken vac line on top of the engine, but after replacing and reseting the computer the codes popped back up within 55 miles. Thought it could be the spark plugs (come to find out they were the original NGKs from 80K miles ago) so I swapped out the plugs. Same thing within 55 miles. My next thought is replacing the two O2 sensors after the precats, but I figured i'd tap the wealth of knowledge that is JF before I continue to fumble around blindly. Thanks!
jrdewitt is offline
post #2 of 4 Old 03-10-2010, 07:04 PM
Gonda
An exhaust leak can cause both of these codes to set. I would start there. Then I would look at replacing the upstream O2 sensor.
I am assuming you engine runs OK...no misfire. If this is in question, check the plugs and the compression first.
Gonda is offline
post #3 of 4 Old 03-20-2010, 01:28 PM Thread Starter
jrdewitt
Just went to the stealership and blew 977.00 on the factory replacement precat/downpipe/cat assembly. Ripped the old one off and looked down the tubes... lets just say it was one of those "Well there's your problem" moments! Only driven about 18 miles since, but could immediately feel and hear the difference! 977.00 is painful, but so is 9mpg and failing smog!
jrdewitt is offline
post #4 of 4 Old 07-19-2010, 02:28 PM Thread Starter
jrdewitt
Just a quick update, passed SMOG with 0 problems... the tech said it was one of the cleanest exhaust readouts he has ever seen.
jrdewitt is offline
Check Engine Light Error Code P0432 PICS! cyclerider105 TJ Wrangler Technical Forum 8 07-17-2012 10:17 AM
It's back!!! code p0420 convertor low eff. vosevichs TJ Wrangler Technical Forum 1 11-05-2010 09:51 AM
OBD Code P0420(M) - possible causes? Kiwi Jeeper TJ Wrangler Technical Forum 8 03-07-2009 01:51 AM
trouble codes P0420 & P0432 KNB7638 TJ Wrangler Technical Forum 1 01-03-2008 02:31 PM
Check Engine Code p0420 gtospeeding TJ Wrangler Technical Forum 12 05-08-2007 11:43 PM
