error code P0135 - JeepForum.com
post #1 of 14 Old 01-10-2010, 02:59 PM Thread Starter
jcspencer01
error code P0135
I am getting this code and was wondering if anyone has any suggestions.
I have a 2001 TJ, 6, manual.. I replaced two o2 sensors this past summer using part number 13664 and 13687 from orielly.
I checked the fuses and they are all ok. are the upstream o2 and downstream o2 the same parts?
thanks
jcspencer01 is offline
post #2 of 14 Old 01-10-2010, 04:54 PM
cj847
OBD-II Trouble Code: P0135 Oxygen O2 Sensor Heater Circuit Malfunction (Bank1, Sensor1)
97 TJ Sport OPJ project (other peoples junk) I can't remember the last time I bought a new part.
cj847 is offline
post #3 of 14 Old 01-10-2010, 05:50 PM Thread Starter
jcspencer01
Thanks for the link.. So which one is that?
post #4 of 14 Old 01-10-2010, 07:41 PM
cj847
Usually bank one is the left bank (or front in the case of an in line 6 with 2 sensors {my 97 only has one sensor}). Sensor 1 is the one in the exhaust manifold. Sensor 2 is the one behind the cat.
cj847 is offline
post #5 of 14 Old 01-10-2010, 07:56 PM
loaderopp
I had the same issues, i traced all the leads, i did an ohms reading on the scensor, bank 1 sensor 1 is the front manifold first scensor.
i replaced the sensor, 4 time 2 after market 2 OEM same thing kept getting P0135, changed the relay, checked the fuses, again checked all the wires, So i threw in the towel and took it to the dealer, they changed the sensor again, and again got the same code, to they hooked up the computer to my system. and found my computer is throwing a false reading/test. they are replacing the Computer on warranty.
Built not bought!!!
2005 Rubicon Unlimited, 5.5 inch custom long arm, 1 inch daystar body lift, River Raider Snorkel, Custom bumper/winch mount, sliders, tire carrier. 37x13.50 R17 Nitto Mudgraplers, Bushwacker flat fender. Custom 1/2 cab. Hyline hood vents. Custom tonnue cover and tool box. HID-X off road lights, LED driving lights custom rear bumper/m6000 rear monted winch.
loaderopp is offline
post #6 of 14 Old 01-10-2010, 08:26 PM Thread Starter
jcspencer01
i have 4 sensors and replaced the two front this summer but dont understand if front and rear are different.
dirtsquirt- that luck sounds like mine. but I am way out of warranty..
post #7 of 14 Old 01-10-2010, 09:24 PM
loaderopp
yes you have 4 sensor 1 bank 1, sensor2 bank 1, sensor1 bank2 and sensor2 bank 2 and yes they are different part numbers ( lead lenght ) is the only Differance
the code p0135 your getting are, O2 heater circuit malfunction sensor 1 bank 1.
check the 20 amp fuse in the master power dist, box under the hood, and check the OSD relay. if you have not done so.
Built not bought!!!
post #8 of 14 Old 09-22-2011, 10:32 AM
mikey600900
I have the same issue, has anyone found a solution?
loaderopp: you said that you were having a new Comp put in, did that end up fixing this issue?
mikey600900 is offline
post #9 of 14 Old 09-22-2011, 10:48 PM
loaderopp
The computer was changed under warranty, and i was still having the problem with P0135. But i did find what the problem was. ETHONAL gas. any time i use it i get a P0135 code. i have watched this issue and noticed, every time i used Ethonal gas i would get the check engine and same code.
I have not used any enthonal gas now for months and have not had the code popup once.
Built not bought!!!
post #10 of 14 Old 09-22-2011, 11:12 PM
Yucca-man
loaderopp - What mixture do you consider "ethanol gas" because it's always mixed in the fuel here in Colorado, or you have 0% ethanol fuel available in Alberta? We're at 5% or 10% normally, I can't recall which off the top of my head. Granted, that's a lot lower than the E85 (85% Ethanol) stuff, but it still contains it - so maybe that's not the actual source of the problems you were seeing?
Yucca-man is offline
post #11 of 14 Old 09-23-2011, 03:14 AM
oakmckinley
I thought the upstream ones were heated? Not just a diff in length?
I am so glad I don't have calif. emmisions
1999 TJ
2010 Mustang
1964 Ford Fairlane 500
oakmckinley is offline
post #12 of 14 Old 09-23-2011, 05:12 AM
TheBucks
One other thing to check. I found the wire harness that went to the front O2 sensor wasn't secured anymore & ended up against the manifold & melted the wires
TheBucks is offline
post #13 of 14 Old 09-23-2011, 08:33 PM
loaderopp
Here reg gas =10% mid = 5% prem =0 i run prem only now no problems.
Built not bought!!!
post #14 of 14 Old 05-24-2016, 08:42 PM
SpecialK2000
how can ethanol in the gas cause a P0135. P0135 means the heater in the oxygen sensor is not working. I don't get it.
SpecialK2000 is offline
What exactly does error code 55 mean? (completion of fault code display on the CEL) Tkahne88 TJ Wrangler Technical Forum 3 11-04-2009 08:46 AM
help with a TJ error code TJdave TJ Wrangler Technical Forum 3 04-04-2008 03:09 PM
Error code Drjones266 TJ Wrangler Technical Forum 1 12-06-2006 12:40 PM
Help, error code 300 Existence TJ Wrangler Technical Forum 1 08-20-2006 01:48 PM
'97 error code TJdave TJ Wrangler Technical Forum 12 11-07-2003 12:04 PM
