error code p0122 - JeepForum.com
post #1 of 25 Old 01-04-2008, 11:51 AM Thread Starter
YoungJeep
error code p0122
The check engine light came on in my 2003 rubicon. I scanned the code and it came up p0122, which is throtle body sensor/switch. The light when off and has stayed off, so i leaving it alone. Has anyone expierenced this code, and can it lead/ruin to other problems/parts. Thanks
natale
YoungJeep is offline
post #2 of 25 Old 01-04-2008, 12:05 PM
robncar
robncar's Avatar
P0122 - Set Condition: Throttle Position Sensor voltage at the PCM is lower than 0.1 of a volt for 1.3 seconds.
POSSIBLE CAUSES
TP SENSOR SWEEP
INTERMITTENT CONDITION
(K7) 5-VOLT SUPPLY CIRCUIT OPEN
(K7) 5-VOLT SUPPLY CIRCUIT SHORTED TO GROUND
TP SENSOR
(K22) TP SENSOR NO.1 SIGNAL CIRCUIT SHORTED TO GROUND
(K22) TP SENSOR NO.1 SIGNAL CIRCUIT SHORTED TO (K4) SENSOR GROUND CIRCUIT
TCM INTERNALLY SHORTED THROTTLE POSITION SIGNAL CIRCUIT
PCM
If it returns, I'd start with a cleaning of the throttle body and TPS (Throttle Position Sensor). If it happens again, replacement of the TPS may be necessary.
3 = TPS
4 = IAC
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #3 of 25 Old 01-04-2008, 01:44 PM
Pointblank
Mine threw the same code a couple months ago. It was still running fine so I unhooked the battery to clear the codes to see if it would throw it again. Ran fine for a few weeks with no further CEL's or codes. Then the CEL came on again, and this time it was running rough. Same code appeared so I replaced the TPS and alls well again.
04 TJ Rubicon, Solar Yellow, 5 speed, 4" suspension lift, 285's(33's), Warn rock crawler front bumper with grille guard, Ramsey 8000 pound winch, JKS UCA's, CV driveshaft
Pointblank is offline
post #4 of 25 Old 01-04-2008, 08:59 PM Thread Starter
YoungJeep
Thankks for the advice! Do either of you remember if you had to calibrate the new sensor, that would be my only hesitation of replacing it myself.
2003 Jeep Rubicon
Inline 6 4.0L
Mopar Chrome bumpers and sidesteps
post #5 of 25 Old 01-05-2008, 07:41 AM
robncar
robncar's Avatar
TPS Removal 4.0L
The TPS is mounted to the throttle body.
(1) Remove air cleaner tube at throttle body.
(2) Disconnect TPS electrical connector.
(3) Remove TPS mounting screws
(4) Remove TPS.
TPS Install 4.0L
The throttle shaft end of the throttle body slides into a socket in the TPS (Fig. 34). The TPS must be installed so that it can be rotated a few degrees. (If the sensor will not rotate, install the sensor with the throttle shaft on the other side of the socket tangs). The TPS will be under slight tension when rotated.
(1) Install TPS and retaining screws.
(2) Tighten screws to 7 Nm (60 in. lbs.) torque.
(3) Connect TPS electrical connector to TPS.
(4) Manually operate throttle (by hand) to check for any TPS binding before starting engine.
(5) Install air cleaner tube to throttle body.
Please note: the torque is inch pounds, not foot poounds.
robncar is offline
post #6 of 25 Old 01-05-2008, 08:51 AM
Chris_
No calibration. Good luck with that. Search and you will find my method of the hammer and screwdriver removal for them. I've changed two. That code will come back. Mine did that.
'02 TJ X Apex Edition
'00 XJ Sport
Chris_ is offline
post #7 of 25 Old 01-28-2008, 04:16 PM
sveipe
I got the same code after I installed my alarm, I guess it have something to do with tapping into the tach wire. I used a wire tap, I am gonna try do a proper soldered splice and see if that helps.
sveipe is offline
post #8 of 25 Old 02-21-2008, 10:36 AM
KrisBenagh
2003 JK Wrangler
My check engine light came on this morning with the same code. P0122, and it is running a little shaky. Is it expensive to fix and will replacing the TPS take care of this?
KrisBenagh is offline
post #9 of 25 Old 03-31-2008, 03:47 PM
pgurt1
I'm getting the same error message P0122.
My gas milage is down 15-25% depending on if on the main roads or in the mountians. I also lose power going up the mountains and have to play with the gas peddle to get it to rev up again.
Are these symptoms typical of a TPS malfunction?
pgurt1 is offline
post #10 of 25 Old 04-07-2008, 10:21 AM
pgurt1
Is there some type of clasp holding the connector to the TPS? I tired removing it to clean the contacts and it does not want to come off. I've looked around for some type of clip holding it place but do not see anything.
pgurt1 is offline
post #11 of 25 Old 04-07-2008, 11:08 AM
Silver04TJ
On mine you just pushed down on the plug that connects to the TPS and it slid right off. Changed my TPS this past weekend due to my CEL coming on all the time and it throwing the P121,122,123 codes. Seems to be find now though.
Silver 2004 Jeep Wrangler Sport
3.5" Rubicon Express Standard lift,
Cepek DC-1 15x10 Black wheels,
33x12.5x15 Cepek Fun Country II!!
M8000 Warn Winch with in cab controls
And the accessory every Jeep should have...DIRT/MUD!
Silver04TJ is offline
post #12 of 25 Old 04-07-2008, 11:09 PM
70_challenger
2014 WK
Look for a lock on the connector (usually a black or red slider type lock). I am not sure which applications use them. Once it is 'unlocked', you should be able to remove the connector pretty easily.
-Tom
70_challenger is offline
post #13 of 25 Old 04-07-2008, 11:34 PM
vitaminwater
Had the same problem...60 dollars later its fixed. Make sure you use a good quality torx bit...
Yellow 2002 TJ Sport
4.0 I6|5 speed|D30, D44 Posi|OME Steering Stabilizer|Homemade Discos|Riddler Diff Covers|31x10.5 Firestone Destination M/T
Build thread:
vitaminwater is offline
post #14 of 25 Old 06-20-2008, 11:25 AM
dskey56
WILDWM Jeep New Hampshire
Had Code P0138 and P0121. Since P0138 was Ox sensor. I went for the TPS. Jeep was running rough also.
The torque screws were hard to get at with my torque bits. So I un bolted the 4 10mm carb bolts and was able to stand the carb up so I could loosen
the two screws.
Also if you do it this way be careful with the casket and cover the intake manifold hole where the carb was so you don't drop anything down there.
Taking the four bolts off allowed me to complete the job in 15 minutes.
dskey56 is offline
post #15 of 25 Old 09-30-2009, 09:30 PM
JeepDoo
subscribed, i need to do this install too.
Hey hey, my my. Rock and roll will never die. - Neil Young
We've got too many gangsters doin dirty deeds. Too much corruption and crime in the street. It's time the long arm of the law put a few more in the ground. Send them all to their maker and he'll settle them down. - Toby Keith & Willie Nelson
Longboard Drunk, Jeep Naked, Ski Powder
and finish calculus homework
JeepDoo is offline
Error codes = P0122 and P0123 Burchie TJ Wrangler Technical Forum 3 03-20-2016 02:48 PM
error code P0122 =TPS, but is it really? zband TJ Wrangler Technical Forum 4 05-26-2013 11:07 AM
Error Codes P0122, P0123, P0138 ernstm TJ Wrangler Technical Forum 1 01-05-2010 04:18 PM
Error Code P0122 Tombstone TJ Wrangler Technical Forum 4 06-20-2007 06:47 AM
error code p0122 bende030 TJ Wrangler Technical Forum 2 09-09-2006 05:43 AM
