Error code help - JeepForum.com
post #1 of 12 Old 08-15-2006, 11:26 PM Thread Starter
TJdave
TJdave's Avatar
Error code help
So my jeep has been running a little rough lately and tonight the check enging light came on and I got code #24 -Throttle position sensor input above or below acceptable voltage. TPS signal does not correlate to MAP sensor.
Anyone know of some things I could check? I kind of want to try to fix it myself. It has been sputtering a lot lately and not idling right at all. Sometimes it will idle at high RPMs and sometimes it will stutter like it wants to die, but it never actually has.
Any suggestions??
1997 Green TJ
RE 3.5 SF Lift Kit w/ Rancho 9000 shocks
Currie AntiRock and HD steering,
KC daylighters, Warn Front bumper
and some
rock sliders all sitting on 33's
NRA Jeeper #9
Ham Radio Call: KI6KCU
TJdave is offline
post #2 of 12 Old 08-16-2006, 12:12 AM
TXjeepTJ
TXjeepTJ's Avatar
buy a new throttle position sensor, i had to do this to mine along time ago, took about 5 minutes to install the new one
sometimes they get wet and screw up
LS1 powered TJ
C6 Z06 Corvette
TXjeepTJ is offline
post #3 of 12 Old 08-16-2006, 12:18 AM Thread Starter
TJdave
TJdave's Avatar
can i get that at pep boys or something??
1997 Green TJ
and some
NRA Jeeper #9
TJdave is offline
post #4 of 12 Old 08-16-2006, 10:48 AM Thread Starter
TJdave
TJdave's Avatar
I called and I can have the part ordered and here on friday but how involved would a job like this be?? By looking at my FSM it lookes pretty simple, but you never know.
1997 Green TJ
and some
NRA Jeeper #9
TJdave is offline
post #5 of 12 Old 08-16-2006, 12:02 PM
TXjeepTJ
TXjeepTJ's Avatar
i can barely remember, i think the sensor is held in by 2 bolts and might be a little challenging to either get to the bolts or take it off
cant really remember but its not that bad!
LS1 powered TJ
C6 Z06 Corvette
TXjeepTJ is offline
post #6 of 12 Old 08-16-2006, 12:13 PM
mattman8706
mattman8706's Avatar
2009 JK Wrangler
that happened to mine just go up to auto zone and get a tps for about 70 dollars and its easy to install just kind of hard to find if you dont know where it is...
-Matt
mattman8706 is offline
post #7 of 12 Old 08-16-2006, 09:18 PM Thread Starter
TJdave
TJdave's Avatar
sweet. I got the part at pepboys for $45 plus tax. We'll see how hard i can make it.
1997 Green TJ
and some
NRA Jeeper #9
TJdave is offline
post #8 of 12 Old 08-17-2006, 09:46 PM
mattman8706
2009 JK Wrangler
wow i wish mine was 45 i think i got ripped off
oh well at least it works
yeah i made it pretty hard but it ended up not too bad when it was all done
-Matt
post #9 of 12 Old 08-17-2006, 09:49 PM
thesherm
thesherm's Avatar
I've seen prices for the TPS all over the map. I cant see how, but I wonder if there is any difference between various brands or if there are different types or something.
98 Sahara
Originally Posted by mrblaine
Unfortunately you are one of those poor misguided folks that believes leaving the gear shift lever in one slot or another is an indication of control.
Come go for a ride and I'll be glad to demonstrate the difference between what you perceive incorrectly as "control" and what control actually is.
Pick a different reason because that one is both lame and stupid to perpetuate.
Pardon me for damaging your precious reputation. It's not that I disagree, that would be a difference of opinion. This isn't subjective, it's objective, you are just wrong. If you make that statement, you are misguided. It is that simple.
thesherm is offline
post #10 of 12 Old 08-17-2006, 10:22 PM Thread Starter
TJdave
TJdave's Avatar
I am picking up the part tomorrow and probably going to try and install it on saturday so I will post how it all goes. It is weird because it drives fine when i am moving but whenever i come to a stop it wants to die on me, but if i keep my foot barely on the gas and revving it is okay.
I hope replacing the sensor is the only thing.
1997 Green TJ
and some
NRA Jeeper #9
TJdave is offline
post #11 of 12 Old 08-17-2006, 10:35 PM
TXjeepTJ
TXjeepTJ's Avatar
tell us how it ends up! it should fix everything
LS1 powered TJ
C6 Z06 Corvette
TXjeepTJ is offline
post #12 of 12 Old 08-18-2006, 12:30 AM
FL 4.0L
Must be easy. Young guy was changing his in the Advance Parts parking lot when I drove in to dispose of some oil tonight.
FL 4.0L is offline
4 cyl. TJ with code error 11 , please help ! kyhunter TJ Wrangler Technical Forum 10 07-28-2011 06:05 PM
What exactly does error code 55 mean? (completion of fault code display on the CEL) Tkahne88 TJ Wrangler Technical Forum 3 11-04-2009 08:46 AM
Error Code 25 BringThaPain TJ Wrangler Technical Forum 4 12-01-2008 08:57 PM
Error code help nettak TJ Wrangler Technical Forum 6 01-30-2008 09:57 PM
Error Code hop2465 TJ Wrangler Technical Forum 5 03-29-2006 07:49 AM
