Error Code 25 - JeepForum.com
post #1 of 5 Old 12-01-2008, 01:58 PM Thread Starter
BringThaPain
Error Code 25
I have a 1997 Jeep Wrangler 68K miles, 2.5 standard. My idle has always been aroung 900-1000 rpm and I noticed that sometimes it would gradually go lower and lower. Well today it died on my while I engaged the clutch (was rounding a corner in a neighborhood). I researched a bit and found that its either a vacum leak or the AIS. Should I replace the sensor first?
BringThaPain is offline
post #2 of 5 Old 12-01-2008, 02:36 PM Thread Starter
BringThaPain
Bumpety Bump
post #3 of 5 Old 12-01-2008, 03:45 PM Thread Starter
BringThaPain
Maybe I need to rephrase my question. Will the AIS motor cause a lower than normal idle? All I have read about the AIS motor, is it causes an extremely high idle. That I do not have any problem with. My problem is it idles just a bit low like its wants to die occasionally.
And is the AIS the same thing as a TPS?
post #4 of 5 Old 12-01-2008, 04:41 PM Thread Starter
BringThaPain
After researching some more, I want to add that my jeep has been "bucking" in second when cold. I don't know if this helps with diagnosis.
post #5 of 5 Old 12-01-2008, 09:57 PM Thread Starter
BringThaPain
A little feedback....Please??????
4 cyl. TJ with code error 11 , please help ! kyhunter TJ Wrangler Technical Forum 10 07-28-2011 07:05 PM
What exactly does error code 55 mean? (completion of fault code display on the CEL) Tkahne88 TJ Wrangler Technical Forum 3 11-04-2009 09:46 AM
Error code help nettak TJ Wrangler Technical Forum 6 01-30-2008 10:57 PM
Error Code hop2465 TJ Wrangler Technical Forum 5 03-29-2006 08:49 AM
a little error code help??? Thrsonly1 TJ Wrangler Technical Forum 2 03-16-2005 10:28 PM
