error code 1281 - JeepForum.com
post #1 of 8 Old 07-11-2007, 10:35 AM Thread Starter
ferger
error code 1281
I've done a search and the only hits I get are people posting the error code lists so I figured that I woud ask specifically. My check engine light came on this morning, I noticed it right after I had to come to a sudden stop (slamming the brakes) it might have been on before that I don't know though. I did the turn key thing and that code that came up was 1281, I looked that up and it says "The engine is staying cold too long - check your thermostat." I'm pretty much a newbie so I have no idea what to do. Is this a serious problem? an easy fix? Any help would be great.
ferger is offline
post #2 of 8 Old 07-11-2007, 10:46 AM
HolidayJeep
Want pie now.
HolidayJeep's Avatar
If it's the thermostat it's a 7 dollar part and a very easy install.
Mike
Originally Posted by Slapahoe
Not to brag, I was the valid victorian my senior year. Best and the brightest of the bottom of the barrel.
Originally Posted by War Eagle
thunderspork
HolidayJeep is offline
post #3 of 8 Old 07-11-2007, 10:50 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Check out the write-up below. On page 2 is where it starts to talk about swapping the t-stat.
http://www.stu-offroad.com/engine/ra...radiator-4.htm
Wheelin98TJ is offline
post #4 of 8 Old 07-11-2007, 12:21 PM Thread Starter
ferger
is it going to be a problem if this doesn't get done right away? Im leaving for the shore 2 hour drive) in a couple of days and im going to be relly busy until then.
ferger is offline
post #5 of 8 Old 07-11-2007, 12:55 PM
Jerky bump
Hate to sound like a wet rag.....
If it is the thermostat- For the amount of trouble and cost to change it- I mean you could overheat in 15 minutes if it failed and put a serious damper on your trip.
Jerky bump is offline
post #6 of 8 Old 07-11-2007, 01:03 PM
Combatsylvania
i agree... change it out.. iit could be done in the amount time it took you to turn on your computer and post the thread.
2006 TJ SE - Does what I want it to do.
Combatsylvania is offline
post #7 of 8 Old 07-11-2007, 02:21 PM Thread Starter
ferger
ok sounds easy enough, do I need just a new thermostat or do I need a new gasket and housing too? Also I looked around and I'm not sure if I need a crown thermostat or a stant thermostat.
ferger is offline
post #8 of 8 Old 07-11-2007, 03:14 PM
Jerky bump
The dealership will have the thermostat -sometimes very competitive on price also. Yeah, new gasket and you should be alright. Not sure if you'll need rtv for the bolts. I used to use it on the threads, just in case coolant got to them.
I doubt one brand is a whole lot better than another-small stuff I usually go to the dealer on. OEM and all.
Be kind to your pets and clean up any spills. 1tsp. may= dead Rover
What exactly does error code 55 mean? (completion of fault code display on the CEL) Tkahne88 TJ Wrangler Technical Forum 3 11-04-2009 09:46 AM
Error Code 25 BringThaPain TJ Wrangler Technical Forum 4 12-01-2008 09:57 PM
Error code help nettak TJ Wrangler Technical Forum 6 01-30-2008 10:57 PM
Error Code hop2465 TJ Wrangler Technical Forum 5 03-29-2006 08:49 AM
a little error code help??? Thrsonly1 TJ Wrangler Technical Forum 2 03-16-2005 10:28 PM
