Engine will not start in cold weather, just makes a single clicking noise - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Engine will not start in cold weather, just makes a single clicking noise
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 01-26-2007, 07:52 PM   #1
Mike1313
Hi everyone, I have a 2001 TJ and when it is very cold outside the engine will not start. When I turn the key nothing happens, just a single clicking noise. If I try turning the key many times (like 10-50) eventually the engine cranks over like normal. When it does crank over it starts perfectly fine. This only happens when I first start the engine in very cold weather.
Everything else works fine, (i.e. radio, etc.) when it won't start, so it's definetly not a bad connection on the battery.
Any help would be greatly appricated.
Mike1313 is offline   Reply With Quote
Unread 01-26-2007, 08:02 PM   #2
surfcaster
Sounds like it's time for a new battery.
surfcaster is offline   Reply With Quote
Unread 01-26-2007, 08:03 PM   #3
Rocky529
Jeep
Rocky529's Avatar
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline   Reply With Quote
Unread 01-26-2007, 08:05 PM   #4
Mike1313
Definitely not the battery, when it does start, even in very cold weather it cranks over just like it was the middle of summer. It doesn't struggle or anything. It kind of a wierd problem
Unread 01-26-2007, 08:05 PM   #5
Fox Fader
It still could be the battery connection. Don't count it out cause the cold cranking amps that are drawed takes a good connection, turing on a radio dosen't.
Starter relay
Ignition switch (key)
Ignition starter switch
God Rules!
Fox Fader is offline   Reply With Quote
Unread 01-26-2007, 08:09 PM   #6
Mike1313
Ya, I'll check the connections on the battery in the morning. Probably have to bring it to the garage to check the switches. I tried to get an error code off the odometer, but nothing comes up, so it's not tripping an error.
Unread 01-26-2007, 08:12 PM   #7
Fox Fader
Shorts normally don't unless they are from a sensor, then the ECU will call it a faulty sensor.
God Rules!
Unread 01-26-2007, 08:16 PM   #8
Mike1313
So do you mean that most faulty electrical switches or relays sould trip an error code, and if no code are tripped then I could just have a bad connection?
It's wierd because when I start in cold weather I can turn the key once and nothing happens, then the next time I turn the key it cranks over fine.
Unread 01-26-2007, 08:48 PM   #9
Fox Fader
No! SENSORS TRIP CODES, not switches & realys. Now they may cause some sensors not to work properly, but this is not the case with 'cranking'.
God Rules!
Unread 01-26-2007, 08:56 PM   #10
97_tj
check your connections at starter and at the battery
97_tj is offline   Reply With Quote
Unread 01-27-2007, 06:55 AM   #11
VTECZILLA
Its the Batt, thats it, nothing else.
2003 Sahara [B]4" Superlift JKS 1.25BL and MML 33" BF-G muds on
American Racing Baja's Magnaflow exhaust. Factory Rubicon Rockers. 10K winch.
VTECZILLA is offline   Reply With Quote
Unread 01-27-2007, 07:23 AM   #12
jm708
1978 CJ7
take your battery to auto zone or some store like that.Most will check it for free. My vote would me the batteyr is bad.
jm708 is offline   Reply With Quote
Unread 01-27-2007, 08:23 AM   #13
Gav'spurplez
i would say if it clicks one time and then you continue to try it,
after how ever many times, then it starts, sounds like a starter
the GCs with the 4.7 had this problem,
i would check the battery too just in case,
1998 Camaro Z/28
1 of 95 in Bright Purple Met.
Basic bolt-ons and 17in DRs.
1999 Wrangler Sport - SOLD
2009 Nissan Frontier Pro-4X
Gav'spurplez is offline   Reply With Quote
Unread 01-27-2007, 08:26 AM   #14
Rule303
I agree. Its could be a starter problem as well . Could be connections or the starter itself. The fact that cold affects it could also mean a bad battery. Just because accessories work doesn't mean the battery is good. Takes a whole lot more amps to start than it does to run a radio.
Sounds like you need to test the battery first, then look further if thats not it.
Rule303 is offline   Reply With Quote
Unread 01-27-2007, 08:28 AM   #15
wcurleyq
I think you sir are correct. My opinion is that the armature in the starter has locked down aginst the windings and then when you hit the key, you are generating heat which expands the outer housing. This in hand gives clearnce the motor needs to start turning, and walla, the engine is running until you cut it off for a long time and the process starts all over.
06 TJ / 4ltr / Auto / 4" Rough Country X / 5 33x12.5x15 M/T Baja MTZ / AA SYE / Tom Woods Shaft / Herculined Tub / Hand Throttle / OBA / AntiRock / Rusty's Crossover Steering / Rock Hard Bumper Carrier / Cheap high-lift jack / Fire Ext / CB
wcurleyq is offline   Reply With Quote
