engine tear down - JeepForum.com
post #1 of 11 Old 02-14-2014, 09:02 PM Thread Starter
twshutika
engine tear down
i have to replace my rear main seal, and since i have the 2.5L it is a one piece seal.
i have decided to then go ahead and pull the engine and also replace all the seal on the engine as well. top and bottom ends,
what else would you guys recommend doing while i have the engine out, , , and no replacing it with a bigger engine isnt on the table.
confidence - the feeling one has before they fully comprehend the situation
Mod List: Rough Country, Genright, JCR, AA, Tom Woods, Mile Marker, Pro Comp, maxxis, Hi-lift, OTRATTW, Rigid Industries, Riddler, garmin, ViAir, Mastercraft, Smittybilt, Pure Jeep, JKS, Rampage
twshutika is offline
post #2 of 11 Old 02-15-2014, 06:19 AM
Jeepsr4me
Really only few oil seals you going to replace, the main and the one on the front behind the dampener and the valve cover gasket, the timing cover and the pan gasket.. If the water pump has not been replaced, then now is a good time also. Same for thermostat.
Jeepsr4me is offline
post #3 of 11 Old 02-15-2014, 08:57 AM
mustanggarage
mustanggarage's Avatar
if you are going to have the oil pan off I would go ahead and pull one of the rod caps and one of the main caps and take a look at the bearings. make sure you don't see any copper.
My yj:
mustanggarage is offline
post #4 of 11 Old 02-15-2014, 01:43 PM
durango-bob
2006 WK
If you are going to tear it apart, you should just buy a full rebuild kit and do it all. That way you won't have to pull it again in 10k miles to rebuild it.
durango-bob is offline
post #5 of 11 Old 02-15-2014, 03:45 PM
jeffjeep1
jeffjeep1's Avatar
I agree with mustang, pull a bearing cap from a main and a rod. But, be prepared for what durango spoke of.
In addition, replace the oil pump while the oil pan is off.
How about removing the transmission, leaving the engine in the jeep and working from below?
Jean - Wonderful wife
2003 Toyota Sequoia
2005 FA64 (aka LJ) Khaki
Heidi - Golden Retriever/Jeep Dog
jeffjeep1 is offline
post #6 of 11 Old 02-17-2014, 09:10 AM Thread Starter
twshutika
im not going to lie, i didnt know you could buy a whole rebuild kit, this is probably what i will look into actually doing.
thanks
post #7 of 11 Old 02-17-2014, 09:12 AM Thread Starter
twshutika
oil pump, water pump, and thermostat will most likely get replaced too, as they are ( as far as i know) 13 years old. . . lol. . .
i thought about pulling the tranny, but i figure i have engine stand and hoist, plus i am probably going to do metalcloaks while i have the engine out so it will all get done in one swoop. . . .
post #8 of 11 Old 02-17-2014, 10:56 AM
Pine_Cat
Pine_Cat's Avatar
If you're up for a full rebuild, then you might consider replacing your crank with a 4.2L crank plus the 4.2L short rods. There are blue-printed, new cranks for sale (see, e.g., 505 Performance), so there's no need to search for used. Such a budget long-stroke conversion will boost your displacement to 4.5L (or greater, if you need to bore out the cylinders), and will have quite a noticeable effect on your low-end torque and trail performance.
It's not done very often because few of us trust ourselves to do a full rebuild correctly, but, if you have the skills, it's a low-cost way of getting a great performance boost.
Pine_Cat is offline
post #9 of 11 Old 02-17-2014, 11:08 AM
Robert J. yates
Wrong advice:
Originally Posted by samgm2 View Post
And yes, I am an exceptional scientist and engineer.
Robert J. yates is offline
post #10 of 11 Old 02-17-2014, 01:59 PM Thread Starter
twshutika
thanks for the info, but i have the 2.5L and the 4.2 crank will unfortunately not work for me. . . lol. . . as for the skill, im a mechanic full time so trusting myself is pretty easy. . .
i think i am going to go with a kit from perfect engine http://www.perfectengine.com/Jeep_2_...h-rcj150ep.htm
then also throw in a new water pump and thermostat .
post #11 of 11 Old 02-18-2014, 05:46 AM
Pine_Cat
Pine_Cat's Avatar
Sorry to have shot from the hip, as I was multi-tasking yesterday, and got so excited about the rebuild concept that I didn't read the thread
Pine_Cat is offline
