Engine struggles to turn over. - JeepForum.com
post #1 of 6 Old 07-10-2010, 09:33 AM Thread Starter
rowarmy
I have a 98 Wrangler and for the past month its become increasingly difficult for me to get her started... my normal start-up sequence goes like this:
1) turn key, hear knocking and whine... wait four seconds.... turn to off
2) repeat 1
3) after 3 or 4 seconds engine catches and starts
I have a Haynes manual has so many possible issues for "Engine will Rotate but will not start" that I really have no idea were to start
Is my starter going? My entire engine/powertrain is original, and runs great with 115K on them, except for a fuel pump that was replaced in december.... Any thoughts or tips on where I could troubleshoot would be appreciated
rowarmy is offline
post #2 of 6 Old 07-10-2010, 10:50 AM
NonRubicon
The whine you describe is probably the starter spinning while not engaged with the flywheel. The knocking is likely the starter teeth trying to engage with the flywheel teeth but not quite fully.
I'd first check the wiring for any faults or damage.
If the wiring looks fine then I would suspect the starter to be going bad. Sometimes starters crap out without a warning and other times they slowly die on you.
NonRubicon is offline
post #3 of 6 Old 07-10-2010, 01:00 PM
wkmincey
How old is your battery? It is possible the battery is bad or going bad or the starter/solenoid is bad. Take the starter out and go to the local auto parts store and have it tested. They can test the battery in the Jeep before you go through the trouble of taking the starter off and can probably "test" the starter while still on the Jeep as well, but the bench test for the starter gives better results and is more accurate in my experience.
The Jeep is gone, I had to have a truck.
wkmincey is offline
post #4 of 6 Old 07-10-2010, 02:03 PM
Dryseals
1980 CJ7
Check the starter solenoid. I have yet to do the one on this Jeep, but most of the ones from modern day engines are serviceable. The contactors in the solenoid which provide power to the starter are usually the culprit. They arc over and pit over time making a less than desirable connection. Makes the engine sound like it's dragging on start or bangs like yours is doing
Many I've seen, you can roll over the contactors or file smooth and be good for the next 100K.
Dryseals is online now
post #5 of 6 Old 12-13-2010, 09:27 AM Thread Starter
rowarmy
got the battery tested... good... still working on getting the starter's solenoid off, bolts are a pain in the butt to get to and are rusted on pretty good
its been working fine since i posted last (albeit I have to try to turn the engine over twice before it catches)... idk if the problem corrected itself or what but it starts and sounds a lot better now
rowarmy is offline
post #6 of 6 Old 12-13-2010, 10:15 AM
Douglas S.
It's only a matter of time until it fails completely. Address it now.
1991 Land Cruiser HDJ81
Douglas S. is offline
tj , wrangler , turnover , turn over , struggle , problem , help
Engine wont turn over, solenoid clicks, hammer tapping starter gets the engine turnin zpmada YJ Wrangler Technical Forum 26 08-16-2011 07:00 PM
notice she struggles when i start her lately 02OlllllllOTJ TJ Wrangler Technical Forum 5 05-10-2010 07:26 PM
chugging, black smoke, struggles under load sutbag TJ Wrangler Technical Forum 1 06-30-2009 09:50 PM
Engine Won't Turn! saltydog785 TJ Wrangler Technical Forum 1 06-15-2009 09:33 AM
Body Lift Struggles RoverJeep90 YJ Wrangler Technical Forum 18 05-05-2008 06:00 PM
