Engine stalls at idle & while driving tries to stall, but doesn't.... No CEL. Ideas?? - JeepForum.com
post #1 of 11 Old 11-19-2009, 11:35 AM Thread Starter
mtngoat
2010 JK Wrangler
OK.... I have searched on the forum for stalling, fuel issues, O2 sensors, TPS issues, PCM issues and I have yet to find someone that seems to have had the same issues I am seeing.
Problem: Just since the weather has been getting colder, I will go out and start the jeep. It starts easy with no issues, idles fine, but will just stop (like I turned off the key). Ok.... I thought....it's just cold. Well last week it started "stopping" while I was driving. Not bucking or spluttering that you might see with an upstream O2 sensor, or bad gas....its like I just turned the key off and back on fast enough that the gauges start to fall back to off state then it resumes where it left off while driving.... It never jumps more than once at a time, but it may do that 2-3 times during the first 15 minutes or so of my daily 40 min commute....
I am completely stumped on this one....I also considered the possibility that the tranny was slipping (auto) but my tach doesn't spike high and it really acts like I shut it off and back on faster than the blink of an eye.... could it be a PCM issue?
Anybody heard or know of this kind of issue?
Thanks!
2010 Unlimited Sport - Mods coming!
2000 Sport - SOLD
WTB: 2" Used OME Springs. PM me w/details
Live for Him.... because He died for you....!
mtngoat is offline
post #2 of 11 Old 11-19-2009, 05:08 PM Thread Starter
mtngoat
2010 JK Wrangler
I considered it might be an electrical issue, but to answer some of your questions first:
When it dies at idle, it just stops (like turning off the key), but all power is still on....radio, lights, etc... While driving, I feel a distinct, sharp lag, like when you hit a slick spot in the road and you lose tire grip. That is why I considered it might be tranny related, but I can see the gauges (tach, speedo) drop then climb back up, but it happens literally as fast as blinking and I do not notice any flicker in lights or distruption from the radio.
So I would be suprised if it was simply power related. I do not have any other noticeable electrical issues or symptoms. Could it be some computer issue, or is there a sensor that I am not familiar with that may cause this?
2000 Sport - SOLD
mtngoat is offline
post #3 of 11 Old 08-01-2010, 11:56 AM
Bova20
was there a solution? having the exact same problem
Bova20 is offline
post #4 of 11 Old 08-01-2010, 12:22 PM
Douglas S.
Check your battery cables.
1991 Land Cruiser HDJ81
Douglas S. is offline
post #5 of 11 Old 09-01-2010, 11:21 PM
Sidewaize
Mine too. I have this problem. Any fixes?
Sidewaize is offline
post #6 of 11 Old 09-01-2010, 11:24 PM
spencerk73
Battery Cables can cause some funky things to happen. Check them first.
"Its not illegal, just frowned upon. Like masturbating on an airplane."
What's you're build? http://www.jeepforum.com/forum/f7/vin-build-sheet-website-1169312
spencerk73 is offline
post #7 of 11 Old 09-02-2010, 12:12 PM
Bova20
Changed spark plug wires on mine seemed to help but it still hesitates with slight rpm drops occasionally.... not as bad as before. Next step im gona take is replacing my battery terminals to see if that will do the rest bc they dont look the greatest
Bova20 is offline
post #8 of 11 Old 10-02-2011, 03:41 PM
joeygto
1999 FSJ Cherokee
My jeep stalls when I am go 35 mph just stalls out sentry key light comes on
joeygto is offline
post #9 of 11 Old 10-03-2011, 08:30 PM
joeygto
1999 FSJ Cherokee
my jeep the sentry key light comes on then it stalls out but starts right back up sentry key light stays on
joeygto is offline
post #10 of 11 Old 08-09-2013, 11:14 AM
venutoa
1997 jeep wrangler
seeing same type of issue. my engine light is on. I know the crankshaft posiion sensor can send a signal to shut off the engine.
that could be it. my jeep would not start the other day and jiggled tge wires near battery and its started.
unsure at this point...but both of what people said in this article could be the problem
will post more when I figure it out
venutoa is offline
post #11 of 11 Old 08-09-2013, 04:57 PM
venutoa
went to autozone and did ODB II scan. mine was the pickup sensor(cam shaft sensor) and the crankshaft sensor. I got batter error showing that it verifyies my thought of a short ....when I jiggled the wires and it started. not sure if the short caused my 2 sensors to go bad...but I'll be looking into rewiring or tracing a short. agggh hate that kinda work. any tips on finding a short? kinda have idea where it is.
I wish someone sold complete wiring harness and I would replace all my wiring
cheers!
venutoa is offline
High Idle on Start Up - Then Nearly Stalls on 4.0L Engine zoom1 TJ Wrangler Technical Forum 14 01-13-2012 12:13 AM
When driving jeep does not hold idle. Rpms just drop and Jeep stalls myoung YJ Wrangler Technical Forum 9 02-26-2010 10:22 PM
94 YJ Engine stutters/chokes at random idle running and driving Awall30 YJ Wrangler Technical Forum 4 02-10-2009 12:36 PM
stall while driving petersone JK Wrangler Technical Forum 1 05-24-2007 03:15 PM
wants to stall at idle robvb525 TJ Wrangler Technical Forum 8 03-14-2005 08:36 AM
