Engine stalling, No check engine light - JeepForum.com
post #1 of 2 Old 09-23-2009, 09:42 PM Thread Starter
gpdaddyo1
97' 4.0, Wrangler. Engine stalls sometimes after 30 miles, sometimes after 200ft. No check engine light. Change fuel pump and filters, pickup in distributor, rotor. Doesn't always start right back up, usually does after it sits. Looking for ideas!!
gpdaddyo1 is offline
post #2 of 2 Old 04-06-2011, 09:11 AM
Juswojo
I had the same issue with my 95. check the connector coming in to the Ignition Coil. My connector was bad causing random connection breaks with the pins in the IC. Replaced the connector and now it runs great. While the engine is running wiggle the wires and move the connector a bit to test. Hope this helps.
Juswojo is offline
check engine light and continous engine hickup GRN_BEAST95 YJ Wrangler Technical Forum 11 09-02-2009 01:19 PM
Speed Sensor/Check Engine Light/Stalling SnatchBlock TJ Wrangler Technical Forum 0 02-27-2009 06:24 PM
blinking check engine light when engine is off but key is on crateampscal TJ Wrangler Technical Forum 7 01-14-2009 10:19 AM
Newby needing help with Check engine light/check gauges/stalling DannyDuvall TJ Wrangler Technical Forum 2 08-23-2008 08:02 AM
Check engine light and engine sthal after cleaning battery posts AirborneSilva TJ Wrangler Technical Forum 4 05-26-2003 11:43 PM
