Engine sputtering when driving - JeepForum.com
post #1 of 3 Old 12-15-2010, 02:57 AM Thread Starter
higgins192
I have a 99 TJ sahara with the 4.0 and when I drive, everything thing is fine then after I shift into 3rd and give it gas it will start to sputter like it's running out of gas then about 2 minutes of fighting it to stay alive it acts like nothing ever happened. (it also does this in 4th and 5th.) Then just recently before it did this the check engine light came on. I'm wondering what this is and how I can fix it.
higgins192 is offline
post #2 of 3 Old 12-15-2010, 10:48 AM
frAnken_rubi
have you checked what the check engine codes are?
Use this to check, Jeep TJ Diagnostic Codes
Post back the code(s) this should allow people to better diagnose the problem.
/l o[____]o
l---L --OlllllllO-
()_)-()_)-o-)_)
http://www.jeepforum.com/forum/f22/frankin_rubi-tj-build-1140219
frAnken_rubi is offline
post #3 of 3 Old 02-02-2011, 07:13 PM Thread Starter
higgins192
well i checked the codes and there where 3. the furst one was sensor 1 failure, 2. high voltage, 3. sensor 2 failure anyone ever had this problem
4.0l , engine , issues , running issues , sputtering
Engine sputtering after some changes cliffy23 YJ Wrangler Technical Forum 9 01-25-2010 12:24 PM
need help engine is sputtering morraz3 YJ Wrangler Technical Forum 10 05-20-2008 08:00 AM
a little help: engine sputtering iking87 YJ Wrangler Technical Forum 5 03-17-2008 02:26 PM
Engine cutting out and sputtering?? BlackedOutJeep TJ Wrangler Technical Forum 7 11-11-2007 06:46 PM
Sputtering engine Remcog YJ Wrangler Technical Forum 9 07-31-2006 06:15 AM
