Engine seems to be flooding at full power - Page 3 - JeepForum.com
post #31 of 33 Old 08-21-2010, 06:58 PM
VnutZ
VnutZ's Avatar
Originally Posted by bmxrules39 View Post
If you have an ohm meter, you will unplug the coil at both ends, set the ohm meter on k or 20k, put a lead where the plug wire connects and the other lead on one of the prongs on the other side (it doesn't matter which one, do both) The ohm meter should read between 10.5 and 15, I believe it was. Mine was 13. I got the specs from autozone, you should just be able to take it in there and they can do this for you.
Ahhh - I just noticed your year. You don't have that coil rail in your model do you?
2006 Black Unlimited on Cummins 4BT
31.5 Gallon Genright Safari Tank (~900 mile range)
4" Long Arm and OME Shocks on 35x12.5"
Vanco Brakes, Ox Lockers and Warn VR10000 Winch
VnutZ is offline
post #32 of 33 Old 08-21-2010, 08:31 PM
chris142
Tip for future referance.
99% of the time a backfire out the intake is caused by a lean condition and a backfire(Actully an afterfire) out the tailpipe is too much gas.
chris142 is offline
post #33 of 33 Old 08-22-2010, 12:09 AM Thread Starter
bmxrules39
thanks chris142, that will help me down the road for sure.
Vnutz I only have one ign coil and a distributor cap, it is different from your 06, that I believe has coil packs?
§wHitt§
bmxrules39 is offline
tj , wrangler , engine , backfire , flooding , tps
Just installed my MC2100 and it is flooding the engine... PMW YJ Wrangler Technical Forum 6 06-17-2010 03:38 AM
A/C will only blow at full power jeepneyJ TJ Wrangler Technical Forum 14 12-28-2009 12:13 AM
Power locks with full doors? D_Dude2000 YJ Wrangler Technical Forum 9 06-15-2007 11:24 AM
Engine randomly shuts down on highway - has full power/fluids/etc. - Help! Alheim YJ Wrangler Technical Forum 37 06-10-2007 11:40 AM
flooding an EFI engine? trw YJ Wrangler Technical Forum 1 03-29-2006 07:01 AM
