Engine seems to be flooding at full power - Page 2 - JeepForum.com
post #16 of 33 Old 07-16-2010, 02:06 AM Thread Starter
bmxrules39
How do I determine where the backfire is coming from?
I don't get any codes, I wish I had one.
wHitt
bmxrules39 is offline
post #17 of 33 Old 07-16-2010, 12:09 PM
bruteboy
a backfire out the exhaust will be a loud bang like a shotgun.
a backfire in the intake will be a muffled pop from the front of the vehicle.
bruteboy is offline
post #18 of 33 Old 08-18-2010, 09:12 PM Thread Starter
bmxrules39
I'm going to bump this thread with a new question.
I've been kind of dealing with this problem, but today I was up wheeling and got stuck, shut off the jeep, hooked up the winch, and the thing wouldn't start back up, a couple of guys got me unstuck and level, then she fired right back up.
I'm thinking that it could be the CPS, that's about the only sensor I haven't had to replace in the last year
wHitt
post #19 of 33 Old 08-19-2010, 12:00 AM Thread Starter
bmxrules39
Ok I got a new cps and it didn't chang anything, now my gas gauge is jumping everywhere, and I have a very rough idle, is it possible I have another bad pump?
wHitt
post #20 of 33 Old 08-19-2010, 12:01 AM Thread Starter
bmxrules39
The back fire is coming from the intake
wHitt
post #21 of 33 Old 08-19-2010, 02:16 PM Thread Starter
bmxrules39
Nobody has any ideas?
wHitt
post #22 of 33 Old 08-19-2010, 03:15 PM
BlueFlame
BlueFlame's Avatar
Sounds to me like low voltage.
BlueFlame is offline
post #23 of 33 Old 08-19-2010, 03:16 PM Thread Starter
bmxrules39
low voltage where?
wHitt
post #24 of 33 Old 08-19-2010, 09:40 PM Thread Starter
bmxrules39
Today I tested my coil it was fine.
I'm still stumped on what it could be, maybe the cam shaft position sensor?
wHitt
post #25 of 33 Old 08-20-2010, 04:47 PM Thread Starter
bmxrules39
Tested the pressure in my fuel rail its only at 22 psi at idle, if I hand throttle it, it drops
wHitt
post #26 of 33 Old 08-20-2010, 11:39 PM
chris142
Lean and not flooding
chris142 is offline
post #27 of 33 Old 08-20-2010, 11:39 PM
chris142
Spec is 49psi I believe.
chris142 is offline
post #28 of 33 Old 08-21-2010, 12:32 PM Thread Starter
bmxrules39
Thanks chris142, I swapped out the fuel pump and everything is back to normal
My PSI is back to 49
wHitt
post #29 of 33 Old 08-21-2010, 02:07 PM
VnutZ
VnutZ's Avatar
How did you do that? Just curious for doing something similar ...
2006 Black Unlimited on Cummins 4BT
31.5 Gallon Genright Safari Tank (~900 mile range)
4" Long Arm and OME Shocks on 35x12.5"
Vanco Brakes, Ox Lockers and Warn VR10000 Winch
VnutZ is offline
post #30 of 33 Old 08-21-2010, 02:29 PM Thread Starter
bmxrules39
If you have an ohm meter, you will unplug the coil at both ends, set the ohm meter on k or 20k, put a lead where the plug wire connects and the other lead on one of the prongs on the other side (it doesn't matter which one, do both) The ohm meter should read between 10.5 and 15, I believe it was. Mine was 13. I got the specs from autozone, you should just be able to take it in there and they can do this for you.
wHitt
tj , wrangler , engine , backfire , flooding , tps
Just installed my MC2100 and it is flooding the engine... PMW YJ Wrangler Technical Forum 6 06-17-2010 04:38 AM
A/C will only blow at full power jeepneyJ TJ Wrangler Technical Forum 14 12-28-2009 01:13 AM
Power locks with full doors? D_Dude2000 YJ Wrangler Technical Forum 9 06-15-2007 12:24 PM
Engine randomly shuts down on highway - has full power/fluids/etc. - Help! Alheim YJ Wrangler Technical Forum 37 06-10-2007 12:40 PM
flooding an EFI engine? trw YJ Wrangler Technical Forum 1 03-29-2006 08:01 AM
