Engine seems to be flooding at full power - JeepForum.com
post #1 of 33 Old 07-12-2010, 12:28 PM Thread Starter
bmxrules39
Well like the title says my engine seems to be flooding at full power.
If I floor it, it just bogs down and, sometimes even backfires.
Also when I'm accelerating it'll go in and out of power a bit.
Could this be yet another tps that needs replaced?
*update
so you don't have to read the whole thread
I have no CEL codes
I have swapped out the CPS and the downstream O2
I have unplugged the TPS, MAP, and the IAC, all of them throw a code and it runs way worse.
I have unplugged the up steam O2 which also makes it run way worse.
My idle is very rough, and if I accelerate any faster than a grandma on her way to church, it'll back fire out of my intake
any ideas are greatly appreciated
wHitt
bmxrules39 is offline
post #2 of 33 Old 07-12-2010, 12:30 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Are you speaking in general or have you already replaced it before?
GOLENJEEPTJ is offline
post #3 of 33 Old 07-12-2010, 01:33 PM Thread Starter
bmxrules39
I have replaced it, about a year ago
wHitt
post #4 of 33 Old 07-12-2010, 03:12 PM
BlueFlame
BlueFlame's Avatar
Could just need a tune up.
First thing I'd check is the air filter...
It could also be that you should learn to not just stomp the gas pedal to the floor...
BlueFlame is offline
post #5 of 33 Old 07-12-2010, 03:32 PM Thread Starter
bmxrules39
I knew someone would tell me not to floor it, the fact is; it's a problem that didn't used to be there, and needs fixing. and further more, if I slowly ease into full throttle I will get the same response at the same point in the pedal position (about 3/4" before floored)
I have checked the filter, its fine.
wHitt
post #6 of 33 Old 07-12-2010, 10:57 PM Thread Starter
bmxrules39
Bump any sugestions?
wHitt
post #7 of 33 Old 07-12-2010, 11:09 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
My first suspicion would be that the upstream 02 sensor is defective which will cause the computer to set the air-fuel mixture to full rich. Try disconnecting the upstream (just below the exhaust header) 02 sensor and see what happens.
Jerry Bransford is offline
post #8 of 33 Old 07-12-2010, 11:44 PM
LRod
I washed my engine and had the TPS go out? Engine off, Put a VOM on ohms, disconnect the TPS, touch two of the three pins, manualy operate the butterfly, the needle should rise and fall with the butterfly position smoothly
LRod is offline
post #9 of 33 Old 07-12-2010, 11:58 PM Thread Starter
bmxrules39
Jerry, thanks for the suggestion. I unplugged it but it still acts like its flooding.
Lrod, I'll try and get my bosses VOM tomorrow and try that out.
wHitt
post #10 of 33 Old 07-13-2010, 12:39 AM Thread Starter
bmxrules39
Now my jeep started having a really rough idle, and I got the CEL. I plugged it back in and its still doing the same thing does that mean anything, or do I just need to unhook my battery?
wHitt
post #11 of 33 Old 07-13-2010, 11:19 PM Thread Starter
bmxrules39
Any other thoughts? It seems like at about 3000 rpms it starts acting up. Does that sound like it could the map sensor maybe?
wHitt
post #12 of 33 Old 07-14-2010, 01:54 AM
asknight
How does unplugging a faulty non-reading O2 sensor change anything?
My money is on TPS and/or O2 sensors.
asknight is offline
post #13 of 33 Old 07-15-2010, 01:30 AM Thread Starter
bmxrules39
I'm not sure I understand your question. When i unplugged it, my jeep acted the same for about 2miles, then if you read futher it really started acting up, I plugged the O2 sensor back in, unhooked the battery, and now we're back to square one with the flooding
wHitt
post #14 of 33 Old 07-15-2010, 01:58 AM
bruteboy
does it backfire out the exhaust or in the intake?
any black smoke out the exhaust?
bruteboy is offline
post #15 of 33 Old 07-15-2010, 02:05 AM
Red_
2016 KL Cherokee
Pull the codes
Red_ is offline
tj , wrangler , engine , backfire , flooding , tps
Just installed my MC2100 and it is flooding the engine... PMW YJ Wrangler Technical Forum 6 06-17-2010 04:38 AM
A/C will only blow at full power jeepneyJ TJ Wrangler Technical Forum 14 12-28-2009 01:13 AM
Power locks with full doors? D_Dude2000 YJ Wrangler Technical Forum 9 06-15-2007 12:24 PM
Engine randomly shuts down on highway - has full power/fluids/etc. - Help! Alheim YJ Wrangler Technical Forum 37 06-10-2007 12:40 PM
flooding an EFI engine? trw YJ Wrangler Technical Forum 1 03-29-2006 08:01 AM
