Engine rust - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Engine rust
FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectRIGID LED Light Blowout Sale - All Sizes, All Series, all Toxic Brakes - 3000 PSI Braided Stainless Steel Brake Line
Unread 04-05-2012, 11:58 AM   #1
jeremyharvey26
Engine rust
I just bought my first Jeep, an '01 with 81K. I noticed under the hood there was a lot of rust parts (belt pulleys, alternator, most parts from the looks of it). I'll snap a picture of it and post it later, but should I be worried or is it normal?
jeremyharvey26 is offline   Reply With Quote Quick reply to this message
Unread 04-05-2012, 12:06 PM   #2
DanZ51
DanZ51's Avatar
Apparently, yours is not leaking enough oil. You need to get that fixed
"I will always be an American Soldier"
DanZ51 is offline   Reply With Quote Quick reply to this message
Unread 04-05-2012, 12:12 PM   #3
TheBoogieman
Always check airbags!
TheBoogieman's Avatar
It's normal to have surface rust in MA.
If you can tolerate the Bilsteins, that will invalidate any discussion you and I may have from now on.They are quite possibly the most annoying damper I've ever used.
TheBoogieman is offline   Reply With Quote Quick reply to this message
Unread 04-05-2012, 12:40 PM   #4
keithert
Best possible answer!
Current: 2005 Wrangler Unlimited - Past: 90 and 92 Trackers and 98 Wrangler SE
keithert is offline   Reply With Quote Quick reply to this message
Unread 04-05-2012, 12:46 PM   #5
shippey-ki-yay
What condition is the rest of the Jeep in?
shippey-ki-yay is offline   Reply With Quote Quick reply to this message
Unread 04-05-2012, 01:14 PM   #6
Necko2529
Rust as in color or rust as in layers that are flaking off?
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline   Reply With Quote Quick reply to this message
Unread 04-05-2012, 01:19 PM   #7
jeremyharvey26
The rest of the Jeep is in great condition, very minimal amounts of rust.
Unread 04-05-2012, 01:22 PM   #8
extsp2
Did you open the hood before you bought it?
"Even duct tape can't fix Stupid"-Ron White
extsp2 is offline   Reply With Quote Quick reply to this message
Unread 04-05-2012, 01:29 PM   #9
jeremyharvey26
Yes I opened the hood and he said it's normal. I've never owned a Jeep before so I wanted to get more opinions on it.
Unread 04-05-2012, 02:17 PM   #10
RowJ
Winter driving in snow belt (salted roads) = Rust.
Regular cleaning underneath after storms can be very effective as rust control and is almost never done, IMO..
RJ
RowJ is offline   Reply With Quote Quick reply to this message
Unread 04-05-2012, 02:22 PM   #11
hallsofstone
Very normal for the rust belt. Feel free to remove those parts, clean them up carefully with steel wool or whatever other rust-removal method you prefer. Anything electrical is better off not getting wet. Take your pick for methods of refinishing and be careful when reinstalling. Might be a good time to "waterproof" your engine bay. Good for keeping your vehicle running if you deal with water crossings. Do a search for methods on that.
Then again, if everything is working fine and the rust is simply surface, take care of other problems that are higher priority first.
[B][SIZE="3"][COLOR="Blue"] Jeeping Ohio Every Day[/COLOR][/SIZE][/B]
00 TJ Sport - Ever evolving DD/Rig [url]http://www.jeepforum.com/forum/f22/jeeping-ohio-hallsofstones-tj-build-1392513/[/url]
85 Suzuki GS700 - ugly
K.C.C.O. [url]www.thechive.com[/url]
hallsofstone is offline   Reply With Quote Quick reply to this message
Unread 04-05-2012, 02:57 PM   #12
jeremyharvey26
Here's an aerial photo of my engine.
Unread 04-05-2012, 03:02 PM   #13
BYuen
Looks normal to me for a rust belt Jeep. One of my buddies bought an XJ from Chicago and it looked like that. I'd recommend you get some engine cleaner or simple green and wash the engine bay out to was away any residual road salt residue etc. Steam cleaning might help to freshen things up too.
BYuen is offline   Reply With Quote Quick reply to this message
Unread 04-05-2012, 03:05 PM   #14
jeremyharvey26
Just wanted to make sure. Thanks dude.
Unread 04-05-2012, 03:10 PM   #15
MFERNICO
Nothing some simple green and then going over the rusty bits with a little wd-40 can't fix.
MFERNICO is offline   Reply With Quote Quick reply to this message
