Engine runs rough intermittently, runs rich... - JeepForum.com
post #1 of 8 Old 10-17-2008, 05:24 AM Thread Starter
Cactus737
My check engine light came on so I changed the oxygen sensor. It still runs rough occasionally and the exhaust really stinks like it's running rich. It almost seems to misfire like the ignition timing is off. Could it be the vacuum? Is this a common problem? Is there an easy fix? Thanks, Scott.
Cactus737 is offline
post #2 of 8 Old 10-17-2008, 05:52 AM
Rocky529
Rocky529's Avatar
Pull the code.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #3 of 8 Old 10-17-2008, 06:50 AM
lilboy1023
I agree with pulling the code. It could be a clogged cat.
lilboy1023 is offline
post #4 of 8 Old 04-22-2010, 07:20 AM Thread Starter
Cactus737
Still Running Rough
Changed the spark plugs and wires and put in a new ignition coil and still runs rough. I'm at my wits end. Any more ideas? Thanks.
post #5 of 8 Old 04-22-2010, 07:25 AM
Alex74012
dont throw parts at it,just pull the stinkin codes
that dd rubi on 37's
Alex74012 is offline
post #6 of 8 Old 04-22-2010, 07:32 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
You don't even need a scanner to pull the code.
You can do it yourself in seconds. Here's how:
How do I retrieve diagnostic trouble codes when there is a check engine light illuminated?
Wheelin98TJ is offline
post #7 of 8 Old 04-22-2010, 07:50 PM Thread Starter
Cactus737
Already HAD pulled the codes. Indicated miss-firing on various cylinders. No further codes.
post #8 of 8 Old 04-22-2010, 08:40 PM
Wheelin98TJ
JEEP FREAK
Well it helps to state what the codes were and that you did pull them.
Did you also replace the cap and rotor?
What kind of replacement plugs did you use?
Have you done a compression test on the cylinders that the misfire codes refer to?
Runs Rich and Runs Rough madjeep1 YJ Wrangler Technical Forum 1 01-04-2010 11:27 AM
Cole Engine Runs Rough 69440dart TJ Wrangler Technical Forum 3 05-22-2009 01:29 PM
Engine swap runs rough iking87 YJ Wrangler Technical Forum 21 04-22-2009 04:07 PM
4.0 Engine runs rough under load need help snaustin09 YJ Wrangler Technical Forum 4 12-27-2008 09:11 AM
engine runs rough until operating temp manion TJ Wrangler Technical Forum 0 09-01-2008 10:20 PM
