Which Engine oil do you use?? - Page 3 - JeepForum.com
post #31 of 79 Old 06-29-2010, 08:25 PM
FL 4.0L
My last OCI I ran a Fram filter that I got as part of an Advance promotion with Valvoline Oil. There is definitely a difference in the color of that oil after 3K miles as compared to after using a NAPA Gold filter. It looks like there is tons more carbon or some other black particulate in the used oil. When I drain the oil after using a NAPA Gold filter, there is reddish/brown look to the oil. I have no idea if this actually translates into more engine protection. I run the NAPA filter for the better anti-drainback valve for just a little more money.
'97 TJ Sport, 4.0L, AX-15, D30/35, BFG TA KO 183K
'12 F30, '03 E46, '06 Rabbit, '13 Jetta
FL 4.0L is offline
post #32 of 79 Old 06-29-2010, 08:28 PM
TheFog
Originally Posted by Robert J. yates View Post
I used to run Rotella T in that weight until they reduced the ZDDP content. Are you sure the Delo still sports it? That weight is typically spec'd for diesels and those levels of ZDDP are DPF killers.
Nice sig BTW
The latest version of Delo 400 is what they call the "LE" version for low emission vehicles. Here is a spec sheet on it http://www.dooilco.com/pdf/Motor%20O...0%2015w-40.pdf Its Zinc and Phosphorous are 1300 and 1200 ppm respectively.
FOG
In memory of Samantha Sue 1998 to Dec-16-10 at 2:15PM. She may have had 4 legs and a tail but she was the best friend I ever had and helped me through some really tough times. I hope to see her again one day.
TheFog is offline
post #33 of 79 Old 06-29-2010, 08:33 PM
00SilverstoneTJ
ive been using mobil 1 since i got my rig. dunno if i can tell you that its better or worse but my car seems to run perfectly. then only downside is that mobil 1 is priccccey!
00SilverstoneTJ is offline
post #34 of 79 Old 06-29-2010, 09:14 PM
Smitty98TJ
Anyone run havoline, the guy i bought the jeep from used this and i'm about to hit 23,000 miles so its about time to change the oil and filter
Smitty98TJ is offline
post #35 of 79 Old 06-30-2010, 07:31 AM
Zen
If it's SAE rated (SL and SM are the current ratings) it will be fine/great for 99% of people. Switching from one to the other will not produce positive effects. Don't add any mystery oils, oil stabilizers, or other wizardry, you don't really know what it will do to the engineered addative packages that are in the oil.
In the OP's case he is not 99% of the poulation. So far his Jeep has seen about 3500 miles per year. If he uses a quality synthetic oil and changes it once a year (12 months), he will likely save money over doing 4 conventional oil changes (every 900 miles and 3 months) per year. The combustion byproducts that get suspended in the oil cause it to oxidize and break down, so even with so few miles driven, dino oil would need to be changed too often to save him money.
-Darkstar, judy-judy. I'm going in for guns.
-Stick, splash one!
Zen is offline
post #36 of 79 Old 06-30-2010, 10:34 AM
DaleII
Does anyone else here run Lucas? We run it in any of the vehicles we maintain ourselves. It's a good product that works.
2005 Silver LJ
DaleII is offline
post #37 of 79 Old 06-30-2010, 10:41 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I hope you're not talking about Lucas Oil Stabilizer, are you?
Jerry Bransford is offline
post #38 of 79 Old 06-30-2010, 10:43 AM
Zen
I don't run Lucas, here's why...
What about Additives?
-Stick, splash one!
Zen is offline
post #39 of 79 Old 06-30-2010, 10:55 AM
mschviuz
Very interesting. I ran lucas in my truck one oil change a while back and noticed quickly that the oil pressure went up about 10psi....not that I needed it to. Note, I don't run it anymore in any of my vehicles. I use castrol and castrol high mileage in my truck that has 120,000 miles on it. To be honest I have always used castrol mainly because I remember, as a kid, my dad always bought it. It has served me well over the years.
mschviuz is offline
post #40 of 79 Old 06-30-2010, 10:57 AM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
i run quaker state, i really have no reason why.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #41 of 79 Old 06-30-2010, 10:27 PM
DaleII
I am. My Dad has used it for years, and has had friends who worked at Lucas. He run Lucas in the trucks that he worked on for the over 30 years. He had engines on trucks go over 1,000,000 miles (yes, 1 million) before needing any major engine work. I believe the stuff in engines. I haven't seen a reason to not use it myself.
We've used it in old motors and it has helped improve cylinder shape and give a better compression. It has also stopped some of our older engines from burning oil as well.
2005 Silver LJ
DaleII is offline
post #42 of 79 Old 06-30-2010, 10:35 PM
NoVaHunter
I run Mobile 1 5w-30 Synthetic and a generic brand filter.
Originally Posted by KHoff90 View Post
Has anyone really been far even as decided to use even go want to do look more like?
NoVaHunter is offline
post #43 of 79 Old 06-30-2010, 11:19 PM
couesfanatic
I run Mobil 1 fully synthetic in my Chevrolet Colorado. Just got back into the wrangler scene again. I plan on running Valvoline 10 w 30 regular. After a nice seafoam of course. lol
couesfanatic is offline
post #44 of 79 Old 06-30-2010, 11:31 PM
Nonya
Pennzoil yellow bottle 10-30 in everything, I change oil every 5-7k with a new oil filter. Bean doing this for many many years and never had a oil related problem.
Nonya is offline
post #45 of 79 Old 07-01-2010, 07:12 AM
Zen
please don't...
If you must: Go to your local mopar dealer and buy mopar combustion chamber cleaner. Follow the instructions on the can or the ones in the MCCC TSB.
-Stick, splash one!
Zen is offline
engine oil , oil , maintenance
Engine code p1281, engine cold for too long....which temperature thermostat to use? ShadowLawz TJ Wrangler Technical Forum 11 11-25-2014 11:23 AM
Engine wont turn over, solenoid clicks, hammer tapping starter gets the engine turnin zpmada YJ Wrangler Technical Forum 26 08-16-2011 07:00 PM
post engine wash problems--engine light on.... PatriotCrawler TJ Wrangler Technical Forum 6 06-21-2007 12:10 AM
Service engine light on!! Is it from H20 in radiator & engine coolant compartment?? chaznad TJ Wrangler Technical Forum 12 04-24-2005 08:57 PM
Check engine light and engine sthal after cleaning battery posts AirborneSilva TJ Wrangler Technical Forum 4 05-26-2003 11:43 PM
