Engine not getting up to operating temp and no heat inside. - JeepForum.com
post #1 of 8 Old 01-03-2014, 11:50 PM Thread Starter
HiPoint
1999 Sahara 4.0L, 3 spd. automatic.
Title pretty much says it all. Temp is barely above the 1st notch on the temp gauge (it was like this in the summer also) and there is no heat on any setting. I replaced the t-stat with a 195* thinking the PO had a 165* in it and no change. I bled the air from the system properly after t-stat replacement.
Anyone have a similar issue? I tried searching this forum and Google with no luck. Heater core clogged? Radiator clogged? Thanks in advance.
HiPoint is offline
post #2 of 8 Old 01-04-2014, 04:57 AM
ky-homelite
Maybe a combination of things? Temp sending unit bad and the heater core plugged up?
ky-homelite is offline
post #3 of 8 Old 01-04-2014, 10:02 AM
JFM626
JFM626's Avatar
Check your actual temperature at the thermostat housing with an infra-red sensor. It will be correct within a couple of degrees. If it is around 200 to 210 after warming up, your thermostat is working fine. If the engine temperature is where it should be turn the heatrr on full blast and check the two hoses going into the heater core at the firewall, one should be at operating temperature -- about 200 the other about 10 - 15 degree cooler. If the cooler one is a lot cooler and no heat is present in the cab then you most likely have a blocked heater core and you will need to flush it. If both hoses are close to the operating temperature, you may have a problem with the blend door, or the heater core fins are plugged with duff.
How can you trust an atom, they make up everything
JFM626 is offline
post #4 of 8 Old 01-04-2014, 10:11 AM
Stu Olson
Stu Olson's Avatar
^^^ Agreed....pick up an infra-red temp sensor. I bought one years ago at the local Harbor Freight and it is still working. I use it to check everything...from my diff housing temps, brake temps, the heat pump in my house, electrical circuit breakers on my house, etc. They aren't that expensive and beats the heck out of guessing when trying to troubleshoot your Jeep!
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
post #5 of 8 Old 01-04-2014, 10:12 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Are you by any chance running a "fail-safe" thermostat? That type of thermostat has a nasty habit of failing in the open position which would prevent the engine from warming up in a reasonable amount of time.
Jerry Bransford is offline
post #6 of 8 Old 01-04-2014, 10:37 AM Thread Starter
HiPoint
The t-stat I recently installed was a Murray 195* from O'Reilly.
HiPoint is offline
post #7 of 8 Old 01-04-2014, 10:46 AM
Jerry Bransford
Administrator
Ok, do you know if that is a fail-safe model or not? Some Murray thermostats are fail-safe designs which are notorious for failing in the open position.
Here's one thread on that... http://www.jeepforum.com/forum/f9/an...tchin-1066813/
I never (!) recommend a fail-safe thermostat, stick with a standard 195 degree thermostat like from Stant.
post #8 of 8 Old 01-04-2014, 02:56 PM Thread Starter
HiPoint
It is not a fail safe model.
HiPoint is offline
