Engine Noise Question 2005 LJ - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Engine Noise Question 2005 LJ
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 07-03-2012, 05:32 PM   #16
FleshEater
Ok...I went at the motor with a stethoscope. The front of the transmission was making the clanging sound as well as the second port (from the front) on the manifold. When I listened to the manifold it really sounded like a diesel. The lower part of the motor all sounded the same and fairly quite as well as the top end. I'll have someone more experienced take a listen and see what they say.
RON PAUL 2012!!!
2005 LJ...only mod completed is rust proofing!
1987 XJ-Bone Stock, 4.0, 5 speed *SOLD*
2002 WJ lifted locked and ready to play *SOLD*
FleshEater is offline   Reply With Quote
Unread 07-04-2012, 06:36 AM   #17
BioTex
OIIIIO
BioTex's Avatar
Hey Flesh, Do you feel confident to remove the pan? Honestly, removing the exhaust manifold is by far the worst of it. If you drop the pan, you can take a peek at the rod bearings one at a time. You will need a torque wrench and a new pan gasket, a couple of standard size rod bearings, and a couple of .001 undersize rod bearings. Total cost of project should be under $50, and the longer you wait, the more damage to the crank journal.
This also gives you access to the timing chain for inspection. They make noise when getting slop/stretch.
'85 CJ7, BDS 4" lift, 1" Body lift, 33x12.5, Shrockworks Sliders, 304 V8 with RV cam., T-176, D300, Dana 30, AMC 20.
1986 CJ10-A SD-33 Diesel/727/np208
1971 800B with 345/T-19
06' TJ Rubicon, 4" R.C. springs, BFG/AT 35s M.C. 6" fenders, rockers and surrounds, Currie front & rear adj. tracbars, tattons DC rear shaft, adj. upper - lower CA's. Bilstein 5100's
YJ Buggy Build Current project. Stroker/FI ?
1990 MJ Comanche 4.0L AX15/np231
BioTex is offline   Reply With Quote
Unread 07-04-2012, 06:39 AM   #18
BioTex
OIIIIO
BioTex's Avatar
Update:
Got the ole girl back together, and started up. Most definately runs quieter. I eliminated the worst of the ticking, but admit that there is still some noises that indicate this engine was abused at some previous time. Very driveable now, and it doesn't worry me like it was before the new #6 rod bearing.
Unread 07-04-2012, 08:22 AM   #19
FleshEater
Honestly my motor doesn't sound anything like the video the other user posted. I think I'll wait this one out...I think it's more exhaust than engine; in the freezing cold there is no noise and after driving in the heat the noise is very, very minimal. If it gets worse as the year goes by I'll definitely drop the pan and check it out. You have to listen very closely for this noise so I'm not overly worried yet...if it sounded as loud as the video I'd be under it today!
RON PAUL 2012!!!
Unread 07-05-2012, 12:18 PM   #20
FleshEater
I had a friend listen to the Jeep and he didn't really notice anything. I'm not even sure if was hearing the same thing I was ha-ha! But he did say that if I want to replace the bearings it's an easy job that we can tackle...so possibly this fall we'll be doing that when the weather isn't miserable. Since it's a cheap fix might as well see if it quiets the old girl down some.
RON PAUL 2012!!!
Unread 07-05-2012, 02:33 PM   #21
-sean-
Pre-cats are most likely rattling around, very common.
L-TJ
L-TJ Dos... Nope
-sean- is offline   Reply With Quote
Unread 07-09-2012, 09:27 PM   #22
-sean-
Any updates?
L-TJ
L-TJ Dos... Nope
Unread 07-15-2012, 03:58 PM   #23
williambmac
Hoppy1962. Your engine sounds like it has a bad lifter.
Rod knock is gonna have a deeper tone to it. Also a rod knock doesn't go away.
2000 TJ 5.5 Long arm, lots of extras. R.I.P.
2005 LJ rubi 35's Clayton, lots of extras
williambmac is offline   Reply With Quote
Unread 07-16-2012, 12:26 PM   #24
FleshEater
Mine hasn't gotten any worse and it just handled a 5 hour drive (each way) quite nicely. Oil pressure is perfect so I'm just going to wait this out...didn't get around to listening to the pre cats yet.
RON PAUL 2012!!!
Unread 07-16-2012, 01:37 PM   #25
-sean-
Is this the noise...
L-TJ
L-TJ Dos... Nope
