engine is misfiring I think... - JeepForum.com
post #1 of 2 Old 10-10-2003, 01:39 AM Thread Starter
jackal
jackal's Avatar
I was on my way to tuscaloosa...and my engine started like jumping...it felt like it was running out of fuel...or not firing or something. I had a 93 YJ before and it sounded like the same thing that happend with the YJ...clogged catalytic converter...so i pulled off the next exit and went to the local muffler shop...and just told them to cut the cat...and weld a pipe..because i didn't have enough money to buy a cat. Alabama doesn't have emmission laws. = ) . Anyway...It was fine until about 80-100 miles later...and it started doing it again...so i have come to the conclusion...it is either (A)engine misfiring (B) spark plugs bad (C) computer in jeep is screwed up. (D) fuel injectors screwed up. I was wondering if anyone else has had this problem before...and wondered what hte problem is...
If it happens...I usually let off...and if i pull over and shut off the engine and turn it back on...it'll run fine again. I have no idea what is going on. Thanks.
JackaL
Green Jeep Club Member # 68
97 Jeep Club MEMBER # 1
1997 4.0L Wrangler TJ 5 spd. 4.56 Locked&Loaded up front..., Remote Start,
Poweraide Throttle Body Spacer,
BanksPower Stinger CAT-BACK,
Advanced Adapters SYE kit
Krylon Fusion Flares!
Skyjacker Dual Steering-Stabilizer
R.E. 5.5" Long-arm Coils
1" Body Lift,
37" MT/Rs on 15"x10" wheels
If they ain't singin'...they ain't slingin'!!
$1000 sound system inside!
jackal is offline
post #2 of 2 Old 10-10-2003, 02:01 AM
DLoweinc
DLoweinc's Avatar
I have no idea but I'm sure someone will get some info to ya..
I'd try the sparkplugs if you haven't changed them in a while because it's something you'll have to do anyways and is pretty cheap.
If you've been in the mud lately you may have clogged your throttle body... happened to my friends ZJ.
Good luck with it
98 Grand Cherokee... Jack Stands, no front axle... Working seat belts!
DLoweinc is offline
Code 302: 2nd cylinder misfiring/overheating engine italianpny43 TJ Wrangler Technical Forum 0 08-16-2009 12:53 PM
engine misfiring at driving speeds djturtle31 YJ Wrangler Technical Forum 3 01-11-2009 11:12 AM
'90 Jeep Wrangler Engine Misfiring Urb4nTr0ll YJ Wrangler Technical Forum 3 12-17-2008 05:24 PM
89 YJ 258 engine misfiring mluko22 YJ Wrangler Technical Forum 3 07-20-2006 06:56 PM
misfiring brundz YJ Wrangler Technical Forum 3 11-21-2005 09:34 PM
