engine light reset? - JeepForum.com
post #1 of 5 Old 03-27-2007, 04:27 PM Thread Starter
jeepster4.0
engine light reset?
how do you reset the engine light on a 2000 sahara, and how can you check the codes like a 2003 or can you???
thanks!
jeepster4.0 is offline
post #2 of 5 Old 03-27-2007, 05:10 PM
blacktjsport
Disconnect the negative battery terminal for a few minutes will reset the check engine light. If it comes back on, you have a problem and need to check it out. Dont understand you second question. On my 2000 I do the key trick and it will flash any code that is stored. HTH
--Matt
~~2000 Black TJ Sport~~
-Parts list keeps growing...
blacktjsport is offline
post #3 of 5 Old 03-27-2007, 05:15 PM
Conundrum
Conundrum's Avatar
Up until 2000 models I believe you cycle the key three times to read the code. On 2001 + model TJs you hold the odometer reset and turn on the key.
Matt
2001 Jeep Wrangler Sport 4.0L - Amber Fire Pearl Coat
1981 DeLorean DMC-12 VIN: 2953
Conundrum is offline
post #4 of 5 Old 03-27-2007, 07:20 PM
ediot
autozone will let you use the scan tool for free.It will read code and erase code.I tried key trick once on my 2000 sport and it did not work.
ediot is offline
post #5 of 5 Old 03-27-2007, 07:23 PM
Conundrum
Conundrum's Avatar
I have to do the key trick on my mom's 2005 KJ CRD and it is a little tricky.
Matt
Is there a way to reset "check engine" light? wildbadbill YJ Wrangler Technical Forum 8 05-01-2009 12:56 PM
Check Engine Light Reset Procedure WORKS! YEA! Overdrive TJ Wrangler Technical Forum 11 12-16-2006 11:28 PM
Check engine Light 03' 2.4 reset Gunkel TJ Wrangler Technical Forum 11 05-07-2006 08:45 AM
How to Reset the computer (Check engine light)? BNovak TJ Wrangler Technical Forum 3 06-27-2004 04:54 PM
Check Engine Light reset skatedork TJ Wrangler Technical Forum 16 06-19-2003 10:59 AM
