Engine Light code 37..torque converter? (Picture) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Engine Light code 37..torque converter? (Picture)
THE NEW! VANCO DUAL MODE 15/16″ Big Brake Kit w/BlaFS: Wranger BRIGHT License Plate LED! Just $3! Great valueEngo winches available at www.rockridge4wd.com! Free shipp
Unread 07-29-2012, 11:37 AM   #1
chupathingy901
The other day my check engine light came on. Did the key dance and i got code 37, something about the torque converter not locking up. I took a picture of my dash At 65 mph. I don't feel it lock in. But it's been like that ever since I bought it a year ago, never a light. I figured the rpms stayed that high because it's only a 3 speed auto. Do my RPMS look normal? If not what should I look for to repair?
chupathingy901 is offline   Reply With Quote
Unread 07-29-2012, 01:46 PM   #2
2003RubiBlue
Hey your out of gas. Seriously though I think those rpms look reasonable.
Quote MrBlaine:
"That's awesome advice. Anytime I have a difficult repair, I fix something else that's much easier to get to. This one time, there was a hole in the oil pan so I replaced the side mirror on the driver's door."
Wanted: Tuffy rear underseat drawer. PM me if you have one.
2003RubiBlue is offline   Reply With Quote
Unread 07-29-2012, 02:09 PM   #3
chupathingy901
Okay, what do you think triggered the light?? And no I'm not out of gas, the sending unit went haha
Unread 07-29-2012, 03:43 PM   #4
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
There are 2 things that can cause the TC lockup CEL.
1. No rpm drop when the PCM looks for it.
2. No 12 vdc input to the PCM at pin B11 of connector C2. Check fuse #11 in the fuse block.
This is for the 2000 32RH, your 1997 my be different... HTH
TSB Information: http://www.automd.com/tsb/jeep_m/wrangler_mm/2000_y/
Knuckelhead is offline   Reply With Quote
Unread 07-29-2012, 10:05 PM   #5
chupathingy901
Fuse is good..I guess I'll reset and see if it comes back.
