Engine Jack Point Question - JeepForum.com
post #1 of 8 Old 06-02-2007, 07:34 PM Thread Starter
95BadBoy
Engine Jack Point Question - Update
Going to put in my BL & BMML tomorrow (it's been sitting around way too long). Body lift looks like no real big deal, but on the JKS BMML instructions it says to use the oil pan as a motor jack point - with a board to spread the wieght across the oil pan.
My question, would I be better to use a board & lift between the auto trans and the block ? If mine were a manual, would most likely use the bellhousing. Just wondering which makes more sence.
Mike
95BadBoy is offline
post #2 of 8 Old 06-02-2007, 08:04 PM
Rocky529
Rocky529's Avatar
Nothing wrong with using the oil pan, just use a 2x4 to distribute the weight evenly.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #3 of 8 Old 06-02-2007, 08:21 PM Thread Starter
95BadBoy
Rocky529
Sounds good, I guess I'll cut a chunk and get with the program tomorrow.
95BadBoy is offline
post #4 of 8 Old 06-02-2007, 08:23 PM
Snakedoc
Snakedoc's Avatar
I was kinda worried about useing the pan and 2x4 but it worked great.
Start on the pass side it`s easier
Drivers side you may have to remove the mount from the block if you have air or take a dremel and grind alittle off the flange on the bolt head.
Don`t forget to loosen the tranny bolts on the bottom of the skid the directions may not day this but it needs to be done.
2004 TJ ~ 4.0L ~ 4sp Auto ~ D30/D35 w/3.73`s ~ 33 X 12.5 BFG M/T
2.25 BB ~ 1.25 BL ~ 1 BMML
1st mod. I like big jugs but they had to go
Black Jeep Club Member #2188
Snakedoc is offline
post #5 of 8 Old 06-02-2007, 08:29 PM
PackMan
PackMan's Avatar
Location: Home of the Super Bowl XLI Champion Indianapolis Colts
I lifted as much as I could from the tranny, but it wasn't enough. In the end, you'll need to use the pan at least for part of this.
I invested in an 8' piece of 4x4 soft pine, and cut it into various pieces. Use it all the time, on the floor jack and across a pair of jack stands.
2004 Rubicon 5spd
33x1250x15 BFG MT on A/R Teflon Chamber (3.75" BS)
2.5" Suspension Lift / 1.25" BL
OME 2.5" (930 front, 942 rear), Daystar 3/4" front spacers, OME N66/N67 shocks, JKS adj track bars, JKS BBL, JKS BMML, really cool toddler booster seats,
Jeeperman bumpers and rockers, IPF 968, Cobra 75WX CB, sPod switches, Cheerios under the rear seat, Skid Row engine and steering box, MORE steering
shaft lift, crayon marks on the sport bar, Napa SC2928 steering stabilzer, Warn xd9000i winch, something that smells bad on the passenger side rear
fender that a child probably had something to do with, HiLift jack, a .357 Magnum S&W, and an Indianapolis Colts SBXLI World Champion window sticker.
PackMan is offline
post #6 of 8 Old 06-02-2007, 09:00 PM Thread Starter
95BadBoy
Thanks Billllll - I did read that on 4x4explor site.
PackMan - I'm also in the process of trying to finish my garage, only one small chunk of 4x4 - but lots of 2x4 pieces.
95BadBoy is offline
post #7 of 8 Old 06-03-2007, 09:29 PM Thread Starter
95BadBoy
Update
Body lift was an absolute walk in the park. About 90 min which included time for coffee & a sandwich.
That drivers side BMML w/AC really kicked my arse !! Wrestled with that one side for almost 2hrs start to finish. The fun factor was pretty low with that side. Passenger side was like 30 min.
That useing a 2x4 thing for lifting the motor via the oil pan did work - but ------- there has to be a better way -- did end up denting in the pan slightly. And for those wondering, no I did not crank on the jack like a madman.
Finally got that out of the way.
95BadBoy is offline
post #8 of 8 Old 06-03-2007, 09:36 PM
Scotch740
Scotch740's Avatar
The driver side wasnt that bad for me, I just took off the Bracket on the motor, 3 bolts. Much easier to get to than the bolts going into the chassis through the mount were.
Scotch740 is offline
Best place to jack up engine? Jeep-5O TJ Wrangler Technical Forum 12 03-05-2008 09:18 AM
4 point harness question Wrangler11 TJ Wrangler Technical Forum 9 07-31-2007 09:52 PM
Differential Housing as a Jack Point? bruker TJ Wrangler Technical Forum 14 07-13-2007 11:12 AM
jack point question Sixxcat1 TJ Wrangler Technical Forum 4 05-19-2004 12:50 AM
Preferred "jack" point? Shinner YJ Wrangler Technical Forum 7 08-03-2003 11:37 AM
