Quantcast engine insulation - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > engine insulation
TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Old 03-09-2008, 06:17 PM   #1
hecubus
1997 XJ Cherokee
engine insulation
quick question: I had to remove the foil sandwiched insulation from the top of the intake manifold to get to some of the the intake/exhaust manifold bolts & managed to destroy the flimsy thing in the process...should I be worried about melting anything?
side note: tightening the bolts fixed my mystery whistle that I've been chasing down for months...woot
"eh, it's the bank's jeep anyway..."
hecubus is offline   Reply With Quote
Old 03-09-2008, 10:57 PM   #2
hecubus
1997 XJ Cherokee
self bump (I ask obscure questions and am used to this )
Old 03-09-2008, 11:15 PM   #3
Michael_K
Old model TJs don't even have this. I wouldn't worry about it too much.
DailyDrivenTJ.com
JUST For Jeep TJ Owners Around the World!
Michael_K is offline   Reply With Quote
Old 03-09-2008, 11:53 PM   #4
Nonya
Its not a deal breaker but it does help insulate the fuel rail and injectors from heat soak when the engine is shut off hot.You could experiance hard starts or false starts in very hot weather.There is a bulletin about it someplace,probably cheap enough to replace it if you are really worried about it.
Nonya is offline   Reply With Quote
Old 03-10-2008, 12:04 AM   #5
hecubus
1997 XJ Cherokee
groovy, that's what I needed to know
...I live in the south so I'll pick up a replacement before the heat sets in
Glock Forum
