Quantcast engine hesitation runs rough until operating temp - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > engine hesitation runs rough until operating temp
Truck-Lite's New LED Headlamp SeriesRuffstuff Axle Simple Swap Kit!Spartan Lockers FREE SHIPPING Excellent Prices
Old 09-02-2008, 06:42 PM   #1
manion
I have a 99 tj 4.0 engine runs rough or cuts out until it warms to operating temp. It actually does this worse if you drive it some where let it sit for about 20 minutes or so then go and drive it, it cuts out hesitates like there is no throttle unless you floor it, then once it warms to operating temp it runs ok. There is no check engine light, I have changed all plugs wires rotor bug and dist. cap I checked fuel psi it was 48 psi and held psi more than 30 psi after the engine was shut off, some one told me it might be the eps so I changed that no help any ideas would be apprieciated. Also every time it rains or I wash it it gets water in the floor board is there a drain some where for the vent?
manion is offline   Reply With Quote
Old 09-18-2008, 09:15 PM   #2
manion
bump bump bump
Old 09-19-2008, 10:47 AM   #3
Mattbastard
My old S-10 did this. Coolant temp sensor made the ECM think it was always up to operating temperature.
Is it backfiring through the intake when cold at times? This is a possibility.
Mattbastard is offline   Reply With Quote
Old 09-19-2008, 11:01 AM   #4
letsgomuddin
1994 XJ Cherokee
Mine did this also, it seemed worse in the winter too. It was my oxygen sensors. If your jeep has over 40K on it, and you haven't changed them, start there. Also a bad temp sensor will cause this too, but keep in mind that there are two temp sensors on your TJ! One is at the thermostat housing and that runs the gauge only. The other is toward the back of the engine on the driver's side.
letsgomuddin is offline   Reply With Quote
Old 09-19-2008, 11:09 AM   #5
bigj1974
cleaned out the idle air controller?
bigj1974 is offline   Reply With Quote
Old 09-19-2008, 02:22 PM   #6
manion
yes since this post I have cleaned the throttle body and cleaned the IAC also have changed the tps thought that the tps fixed it as it didnt do this for a couple of times but it is still there doing same thing.
Old 09-19-2008, 03:06 PM   #7
Zew
I have this same problem and the only thing i didn't change out was the engine coolant sensor. I think that's gonna be my next try. I changed the O2's, tried 3 different sets of spark plugs, 2 cap and rotor sets, 2 sets of wires, TPS, CPS, CamPS, replaced the coil and Cleaned the IAC and TB. Nothing helped.
Zew is offline   Reply With Quote
Old 09-19-2008, 03:27 PM   #8
angryjohnny
I had the same exact problem I disconnected the front bank o2 sensor it runs like a champ now it throws a code I know this is a temp fix for it i havent figured it out yet but i do know my cat is very bad so i was going to start there after fixing that i was thinking o2 sensor or o2 sensor but in the meantime to get rid of the problem disconnect the plug on the front o2 sensor it worked for me i have been running mine for over 2 years like that i just got to get around to troubleshooting it further but my first step is the cat
AJ
angryjohnny is offline   Reply With Quote
Old 09-21-2008, 09:58 PM   #9
angryjohnny
AJ
Any Luck did it work for you??
Old 10-06-2008, 09:55 PM   #10
manion
yes been driving it like that for two weeks im going to change my 02 sensor first then try a cat.
Old 10-06-2008, 10:27 PM   #11
angryjohnny
Let me know how it works out for you
AJ
Old 10-19-2008, 10:47 AM   #12
Jake2687
Junior Member
I posted in another thread that I also have a 99 TJ that is running rough when cold. I changed the front temp sensor (anyone know if that's the gauge one or the computer one?) I've also changed the throttle position sensor and neither have helped at all. Haven't tried the O2 sensor yet, where is the one that I can unplug? Any other suggestions would be greatly appreciated.
Jeff
Jake2687 is offline   Reply With Quote
Old 10-20-2008, 04:23 AM   #13
Jonny Jeep
Jonny Jeep's Avatar
Look down at the exhaust manifold where the exhaust clamps up to it. The upstream O2 sensor is just below that joint. Follow the wiring up to the inlet manifold where you'll find the connector.
The problem is caused by the heater circuit in the O2 sensor going bad. Here's a couple of recent threads on the subject...
http://www.jeepforum.com/forum/f9/engine-sputters-first-few-min-operation-619474/#post5861353
http://www.jeepforum.com/forum/f9/97-tj-sputter-stall-o2-sensor-612880/
"Giving English to an American is like giving sex to a child. He knows it's important but he doesn't know what to do with it."
Adam Cooper (19th century)
Rockauto 5% discount code can be found here... http://www.markviii.org/LOD2/products_services.htm
Online factory service manuals can be viewed at http://www.jeep4x4center.com/knowledge-base/index.htm#service
Parts list PDFs available from http://www.berrysprinter.com/jeepparts.php
Jonny Jeep is offline   Reply With Quote
Old 10-21-2008, 01:32 PM   #14
Jake2687
Junior Member
Thanks Jonny, I'll have to give the o2 sensor unplugging trick a try, i'lll update after I figure it out
Old 01-27-2009, 10:17 AM   #15
angryjohnny
Did the 02 sensor ever fix it for you ?
AJ
Glock Forum
