engine hesitating while in gear? clutch going bad? - JeepForum.com
post #1 of 7 Old 05-21-2009, 12:22 PM Thread Starter
WhatBump1
So I drive and the engine starts loosing power when in gear, possible causes, bad gas or clutch going bad, engine has 122K on it full tune up at 118k with new plugs,wires, distributor and rotor....help my Jeep mechanic is on Vacation
97 TJ Pearl Blue I6, 5 spd,
85 CJ7 Laredo 4.2 with HEI fuel Injection (project)
BMW Z4 M Coupe to Jeep TJ to Jeep CJ7 to BMW R1200C
WhatBump1 is offline
post #2 of 7 Old 05-21-2009, 12:23 PM Thread Starter
WhatBump1
and yes it runs fine when out of gear
post #3 of 7 Old 05-22-2009, 05:25 AM
Justin Brimm
I don't know the answer to this but my TJ does basically the same thing. Sometimes when pushing in the clutch (almost always at a stop but sometimes while moving, even at freeway speeds) the engine will drop down to ~200 rpm and chug and buckjump until I let the clutch back out. It'll also stop doing it if I throw it in neutral.
Justin Brimm is offline
post #4 of 7 Old 05-22-2009, 11:19 AM Thread Starter
WhatBump1
well I finally concluded that I have a fuel sending unit that is on its last leg, will replace it and see
post #5 of 7 Old 05-23-2009, 12:38 AM
CO_crawler
yeah sounds fuel related to me to.
CO_Crawler
Crawlin Slow Some Where in CO
CO_crawler is offline
post #6 of 7 Old 05-24-2009, 06:46 AM Thread Starter
WhatBump1
I swear .....
Well.....I swear my TJ has a mind of his own. stopped doing it after I put a fuel injector cleaner in the tank and filled it with 89 octane. Has not lost power for the last 50 miles, will wait to replace the fuel sending unit... maybe it just wanted its injection cleaned. But there are no error codes and thge engine light does not come on
post #7 of 7 Old 05-31-2009, 07:50 AM Thread Starter
WhatBump1
Replaced the fuel sending unit and it still does it, starting to pull my hair out,...oh wait I do not have any left to pull out
89 hesitating in third gear with webber carb help!! mekken YJ Wrangler Technical Forum 3 12-01-2009 01:25 PM
Hesitating engine WhatBump1 TJ Wrangler Technical Forum 12 05-09-2009 04:30 PM
clutch won't go into gear when engine on wannabeoffroadr YJ Wrangler Technical Forum 3 04-25-2009 01:37 PM
94 with 4.0. HO and auto trans and AC, hesitating in gear. jrad YJ Wrangler Technical Forum 3 05-04-2008 04:46 AM
hesitating engine.... bananamane YJ Wrangler Technical Forum 20 08-28-2004 09:27 AM
