Engine cutting out - JeepForum.com
post #1 of 13 Old 06-23-2006, 06:50 AM Thread Starter
mojorizn1
Engine cutting out
I am a long time jeep owner. This is my 4th. A '98 4cyl. with 109,000 miles on it. My problem started last summer, and has recently gotten worse.
The engine will just cut out, for only a second. Like it is getting no gas. Then it is fine. Only recently when it does it, it does it 2-3 times in rapid succession. Any gear, any time.
Could it be the fuel pump? Clogged catalytic (sp?) converter? How would I check these items?
Thanks
mojorizn1 is offline
post #2 of 13 Old 06-23-2006, 09:54 PM
Dukes69
Dukes69's Avatar
sounds like what happened to me when my fuel pump strainer, or pre-filter, got plugged. Try replacing that and good luck. OH, btw, the strainer is not available at the dealer, try your local parts place.
AIM: Dukes69
Ya Savvy?
Dukes69 is offline
post #3 of 13 Old 06-23-2006, 11:38 PM
Stu Olson
Stu Olson's Avatar
Cuts out.....I would venture a guess towards the ignition side of the equation.
Fuel, air, and spark....you need all three. IMO, loss of spark is much more like a light switch being turned off and then back on. I honestly don't think a fuel filter has as much change of plugging up and then unplugging like that and cause your engine to cut out.
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
post #4 of 13 Old 06-24-2006, 02:36 AM
JeepGal
JeepGal's Avatar
It happens because as the fuel tank gets low, the concentration of debris in the fuel get worse. The more fuel in the tank, the less likely the problem will occur, but as the strainer gets more and more clogged, it will happen regardless of the fuel level.
If nothing else works for you, let the tank get low, drop the tank, pull out the fuel filter, and remove the strainer. Post back here with pics, Im curious if its the same problem.
Tam
JeepGal is offline
post #5 of 13 Old 07-01-2006, 03:20 PM
bittleloylube
Engine also cutting out
I have noticed the same thing. But it seems to happen after I have driven around 12-15 miles on interstate @ 70-75 mph. Does your check engine light come on when this happens. When it started I replaced plugs, wires, rotor and distributor, problem still occurs. Although I have not figured out the fix, I have found that if I engage the clutch and coast for a few seconds, enough to let the rpm drop, I do not have the problem--I do this when I've driven about 6-7 miles.
Am curious if anyone else has had sim response, and what the problem is.
Thanks, JEff
bittleloylube is offline
post #6 of 13 Old 07-01-2006, 07:54 PM
cpleasant
cpleasant's Avatar
Try the forward o2 sensor. It is notorious for causing the engine to buck like that. On the 98 6cyl I used to have it would buck like it wasn't getting gas. It would do it shortly after driving off after starting. The bucking would stop (from what I remember) after bucking a few times. Changed the o2 sensor and the problem went away. This also seems to be common after having a cracked exhaust manifold. So if it turns out to be the o2 sensor you may want to check the manifold for cracks.
Originally Posted by liredneck View Post
I know your rite I seid the dealer seid the same thing as you and that I don't want them there , but I was asking another qeustin as in what do I do about the slots in the brackets couse if I just put a bolt in there it will slide back and fourth but again thank you all knowing and powerfull jeep god sorry us lesser jeep peeons might have some more qeustins in the future , so please if there to much for you sit back relax go to the next post
cpleasant is offline
post #7 of 13 Old 07-01-2006, 11:24 PM
bittleloylube
Great!
Did have to replace the exhaust manifold, and problem started after it had cracked.
Thanks for the help.
post #8 of 13 Old 07-01-2006, 11:27 PM
Muddy Tj Zack
One of those gadgets that actually works....Fuel Injector cleaner. Will do wonders. Advance Auto has Valvoline Synthetic buy one get one free, try it out. It works. Mine was doing as you described but so bad to the point were it didnt want to move anymore. Run great 5,000 miles later!!
'97 Tj Sport, 4.6L Stroker, 5-Speed, 4-in suspension lift, 35" TrXus M/t's, Dana30/Ford 8.8 w/ Aussie Locker, Teraflex ExtremeShort SYE, custom front and rear bumpers, Flowmaster Off-road Series, and a bunch of other goodies........MoPar or No-Car!!!
Muddy Tj Zack is offline
post #9 of 13 Old 07-02-2006, 12:35 AM
cpleasant
cpleasant's Avatar
Like I said, the o2 sensor going bad is VERY common after having a cracked manifold. Let us know if this fixes it.
post #10 of 13 Old 07-03-2006, 01:26 PM
TAS
TAS's Avatar
Mine did that very thing a while back. Turned out to be the CPS (crank Position Sensor). It would be running fine then, just cut out for a sec or two then, it would be back to running fine. I just unplugged it, cleaned it and plugged it back in.
Todd
98, I6, 5spd, 4" Lift, 33's and a few other mods that get me there.
Tow rig - 12 F-350 4x4
TAS is offline
post #11 of 13 Old 08-10-2009, 12:13 PM
livelarg
Soooo.. Where is the crank position sensor?
Thanks
livelarg is offline
post #12 of 13 Old 08-11-2009, 04:55 PM
(Black_Jeep)
Check this out then if you have no idea where its at.
http://www.4x4xplor.com/cps.htm
The Horror...
(Black_Jeep) is offline
post #13 of 13 Old 08-11-2009, 05:00 PM
livelarg
Thanks for the info. I was looking at a bunch of other posts and found people with the exact same symptoms. One suggestion was to disconnect eh upper o2 sensor. I did it and the jeep is running perfect. So I am going to put in a new o2 sensor, and hopefully all will be well.
Thanks
livelarg is offline
Engine cutting out bhowe YJ Wrangler Technical Forum 4 11-10-2011 07:53 AM
4.0L Engine cutting out around 2,000 RPM Dust4Life TJ Wrangler Technical Forum 5 12-29-2008 07:41 PM
Engine cutting out rtingley YJ Wrangler Technical Forum 3 03-31-2007 02:42 PM
Engine cutting out........HELP JIMMYJONES TJ Wrangler Technical Forum 5 07-17-2006 05:58 PM
Need Help Engine cutting out meador36 YJ Wrangler Technical Forum 6 11-10-2004 09:07 PM
