04-03-2012, 03:27 PM
#16
Rotors will warp from a number of things, including overtorque. Ever hit the brake pedal and have the steering wheel shake like a wet dog?
04-03-2012, 03:31 PM
#17
Has anybody (you or your 'mechanic') recently added any fluids to your 'engine'? If so, what was added and where was it added?
In addition to a seized caliper causing your issues you could also have a swollen brake hose that is preventing the caliper from releasing.
The coolant... flush your radiator and heater, get a new radiator cap (even if your old one looks fine) and refill it with NEW clean fluid from a sealed bottle - if you get the undiluted antifreeze be sure to cut it with distilled water, not spring water or tap water.
04-05-2012, 09:43 PM
#18
Thanks for all the help guys... AND BTW i might have mixed the 2 diff engine coolant..... got some work ahead of me, thanks
30A&MUD4ME
04-05-2012, 10:12 PM
#19
Why do you say you might have? Did you or did you not? If you did you have to drain it, flush it out REALLY good and refill with correct fluid.
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
04-06-2012, 07:38 AM
#20
Fix you brakes before messing with the cooling system.
It is entirely possible the the overheating is caused by the excessive load the stuck caliper is putting on the engine just to move the Jeep.
Think about it for a second, it's like driving with one foot on the accelerator and the other pressing on the brake pedal.
Vince
04-06-2012, 08:07 AM
#21
why is the coolant red??? it can not be that rusty... sounds like someone mixed wrong coolants... you need to at least pull the lower hose and drain all that mess out... replace with 50/50 premixed antifreeze, check t stat and water pump, make sure radiator is not clogged with mud or blocked somewhere, check fan clutch and drive and see if that helps... 83 in atl is not hot yet at all...
brakes: caliper bit the dust... replace both sides at a time and this would be a good time to get new rotors and pads and call it done!
04-06-2012, 08:15 AM
#22
Vince
I agree that the brake issue (stuck caliper) has placed additional load on the engine/drivetrain, but that shouldn't cause it to overheat. I would believe there's a cooling problem too that reared it's head with extra load. Any bets on the cooling issue?
Radiator Cap
Cooling Fan
Water Pump
Clogged/Mixed/Ignored Coolant
I'll put $5 on the Cooling Fan
"I will always be an American Soldier"
04-06-2012, 08:30 AM
#23
And do it ASAP!
While I def agree that the brakes have to be addressed, I would contend that the cooling system (at least the flush and fill) is the priority; mixing any other type of coolant with HOAT causes rather caustic chemical reactions that are extremely bad for our engines' guts.
Red/pink/orange is the correct color, the color of Zerex G-05 and Mopar HOAT coolant that is called for in his '04.
Gear-Calculator Stu Can Help You Part Names and Numbers Dealer Supplied Parts and ask for "Jeep Club" Prices
Originally Posted by Ron Paul
“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
04-14-2012, 10:15 PM
#24
Replaced the Caliper... 20 bucks and did it myself so im happy with that..... And new coolent.... has fixed that too. But now behinde the brake where that side ways U shaped thing is that holds the whole tire there is the axe and a little plastic cap like thing.... It was stuck out and I guess axle grease (gray in color) was leaking slowly out.... I got a hammer and screwdriver and hammered it back in to place as best I can. It has stoped the leak but is still out a little bit. IDK how this happend. I need to get a better angle at it so i can knock it all the way back into place. (the rotor is in the way....
30A&MUD4ME
04-15-2012, 08:33 AM
#25
The plastic thing is just a dust shield, its not a seal. Axle seals on the D30 are in the diff. If you are leaking gear oil you will need to replace them there. Messing with the dust shield not fixing anything.
2013 NORRA Mexican 1000 - Co-Driver #199
2012 King of the Hammers - Hammerking Productions "Intern"
HELP KEEP JOHNSON VALLEY OHV AREA OPEN: http://www.savethehammers.org/
04-15-2012, 08:51 AM
#26
If you have the fluid coming out from the axle, make sure you check your fluid in the front diff.
If you sunk it in water it may be contaminated and over full or if you have not, and it has leaked through the seal, then you are most likely low on fluid.
04-15-2012, 09:23 AM
#27
If radiator fluid leaves an oily residue in overflow bottle and fluid color gets darker, dirty looking, it's possible to have an internal leak in radiator trans cooler if equipped. Had that happen on a Dodge truck. Sounds more likely only the flush and coolant change were needed
