Engine Code P0463 ANY KNOWN FIX YET? - JeepForum.com
post #1 of 12 Old 03-01-2011, 04:31 PM Thread Starter
WILLY348
I've had this engine code for probably 2 years now. My jeep runs just fine, but it'd be nice to get it gone. I can just quote myself from the last time i posted about this issue..
Originally Posted by WILLY348 View Post
After probably atleast 4 months i am still getting this engine code. I dont know how the heck to make it go away. What happens is every single time i fill my tank up, i will go home and the next morning i get up to go to work ill let it warm up and idle for about 15 minutes and the code comes on. Now, if i dont ever let it sit there and idle, the code will NOT come on. What happens is after i burn through a few gallons, the code goes away.
When the light comes on, the gas gauge reads zero. I then turn the jeep off, and the gas gauge reads full again, but check engine light is on. Any one know how to fix this?
I've just been living with it because it doesn't affect the drive ability at all, but i would really like to get this fixed.
WILLY348 is offline
post #2 of 12 Old 03-01-2011, 04:33 PM
mouse
P0463 Fuel Level Sending Unit Volts Too High. Fuel level sensor input above acceptable voltage.
mouse is offline
post #3 of 12 Old 03-01-2011, 04:34 PM Thread Starter
WILLY348
I've seen that before, but i want to see a fix for it
WILLY348 is offline
post #4 of 12 Old 03-01-2011, 04:36 PM
mouse
It my require pulling the tank and replacing the sending unit. I don't know I'm still looking..
mouse is offline
post #5 of 12 Old 03-01-2011, 04:37 PM
ChaseB
I would start by replacing the sending unit lol
1984 CJ-7 Renegade
2005 TJ X (daily driver)
ChaseB is offline
post #6 of 12 Old 03-01-2011, 04:41 PM Thread Starter
WILLY348
So this is what i'll be looking at that needs to be replaced? http://www.quadratec.com/products/51306_143.htm
Thank god i'm an '06. The 03-04 fuel sending units for the LJ's cost $399.99! http://www.quadratec.com/products/51306_142.htm
WILLY348 is offline
post #7 of 12 Old 03-01-2011, 04:43 PM
ChaseB
That's it, there may be a cheaper one available. You'd have to check the parts houses but I'm doubtful. Probably better off going with the Mopar unit. I don't suppose you have any warranty left on your Jeep?
1984 CJ-7 Renegade
ChaseB is offline
post #8 of 12 Old 03-01-2011, 04:48 PM
mouse
Oh gosh that's a lot for such a small pert...
mouse is offline
post #9 of 12 Old 03-01-2011, 04:49 PM
ChaseB
ehh, even the one for my CJ is over 100 bucks.
1984 CJ-7 Renegade
ChaseB is offline
post #10 of 12 Old 03-01-2011, 04:53 PM
mouse
I just never thought it would be all that much for a part like that..
mouse is offline
post #11 of 12 Old 03-01-2011, 04:53 PM Thread Starter
WILLY348
Nope, my LJ only had a 36,000 mile warranty.
WILLY348 is offline
post #12 of 12 Old 03-01-2011, 04:54 PM
ChaseB
You'll save some cash doing this yourself. It isn't overly complicated, but it is a pain in the ***
1984 CJ-7 Renegade
ChaseB is offline
Code p0700 and p0463, What is it. popeyesides TJ Wrangler Technical Forum 3 06-20-2015 01:04 PM
Code P0463 What is it? popeyesides TJ Wrangler Technical Forum 15 06-20-2015 12:47 PM
Misfire code P0301 & Fuel level code P0463 related? -OlllllO- TJ Wrangler Technical Forum 6 04-28-2010 03:55 PM
Engine code P0463 still happening WILLY348 TJ Wrangler Technical Forum 0 07-11-2009 03:43 PM
scan code p0463 mJUSTINm TJ Wrangler Technical Forum 5 03-01-2009 09:06 PM
