which engine code is this? - JeepForum.com
post #1 of 18 Old 05-28-2010, 09:02 AM Thread Starter
oren77
1998 TJ 4.0, engine code PO138, O2 sensor circuit high volts (bank 1 sensor 2). any pics of which sensor it is? is there a part number for the sensor?
oren77 is offline
post #2 of 18 Old 05-28-2010, 09:12 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
You should replace both of them at the same time if they haven't been replaced before.
TheBoogieman is offline
post #3 of 18 Old 05-28-2010, 09:14 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
That is the downstream 02 sensor which is located right in the cat converter.
The part # for a dealer replacement is 56041213AB and it lists for $95.30. If you can get a discount, price will be around $63.44.
Have you tried clearing the code and see if it comes back?
Wheelin98TJ is offline
post #4 of 18 Old 05-28-2010, 09:17 AM Thread Starter
oren77
Tried clearing the code and keeps coming back. Seems a bit pricey, is it suggested I replace both of them? Is there a place online that has them for less than the dealer?
oren77 is offline
post #5 of 18 Old 05-28-2010, 09:20 AM
biffgnar
biffgnar's Avatar
Best place I have found for OEM sensors is Mopar Parts for Dodge, Chrysler and Jeep: MoparPartsAmerica
biffgnar is offline
post #6 of 18 Old 05-28-2010, 09:25 AM
Wheelin98TJ
JEEP FREAK
$63 is a decent deal, but yea, $90+ is getting a little expensive.
An 02 sensor from Autozone is $75 and it will be a piece of junk Bosch sensor.
I would look it up at Mopar Parts America (the link provided above by biffgnar) , print the page, and take it to your local dealer. Tell them you want an 02 sensor for $63 or you are ordering it online.
post #7 of 18 Old 05-28-2010, 09:26 AM
TheBoogieman
post #8 of 18 Old 05-28-2010, 09:35 AM
Wheelin98TJ
JEEP FREAK
I'm not sure if that one will work.
The stock downstream sensor is a heated sensor, so it uses a 4 wire connection.
post #9 of 18 Old 05-28-2010, 09:41 AM Thread Starter
oren77
so if I were to replace both of them, is it the same part number, 56041213AB?
oren77 is offline
post #10 of 18 Old 05-28-2010, 09:41 AM Thread Starter
oren77
looking at the oem one
oren77 is offline
post #11 of 18 Old 05-28-2010, 09:50 AM
Pillswoj
I agree the Bosch are junk, NAPA carries the TGK sensors which work well (and they may be the ones to make the oem)
Friends don't let Friends run Bosch
Pillswoj is offline
post #12 of 18 Old 05-28-2010, 09:52 AM Thread Starter
oren77
is it the same part number to replace both of them?
oren77 is offline
post #13 of 18 Old 05-28-2010, 09:53 AM
Wheelin98TJ
JEEP FREAK
They have different part numbers, but coincidentally the same price.
Upstream 02 sensor
56041212
List price $95.30
Downstream 02 sensor
56041213AB
List price $95.30
post #14 of 18 Old 05-28-2010, 11:45 AM
vector6
vector6 is offline
post #15 of 18 Old 07-02-2010, 09:55 AM Thread Starter
oren77
Just purchased both sensors from the dealer, took them a printout from moparpartsamerica and they gave me a discount. Just went under the jeep to locate both sensors, and i only see one it is located just after the exhaust manifold. Where is the other sensor?
oren77 is offline
02 sensor , oxygen sensor , p0138
Engine code p1281, engine cold for too long....which temperature thermostat to use? ShadowLawz TJ Wrangler Technical Forum 11 11-25-2014 11:23 AM
Engine Code P 304, Engine code P0304 JeepinRRT TJ Wrangler Technical Forum 4 09-23-2009 09:26 AM
"Check Engine Light" and engine code P0442 MDC3 TJ Wrangler Technical Forum 3 08-05-2009 01:38 PM
97 TJ engine code 12 31 55 mojoblue TJ Wrangler Technical Forum 3 08-04-2009 12:56 PM
Engine Code Help! osudelt69 TJ Wrangler Technical Forum 3 06-24-2007 08:55 PM
