Engine clicking every morning after startup... - Page 2 - JeepForum.com
post #16 of 23 Old 07-09-2010, 05:36 PM
LJameson
Also, just an FYI. This is in my Factory Service Manual for my CJ7. It's on a problem tree for the valvetrain on a 258; which is identical to the 4.0's:
1990 YJ
LJameson is offline
post #17 of 23 Old 07-10-2010, 06:15 PM Thread Starter
bjjfoshizzy
Great, thanks guys!
bjjfoshizzy is offline
post #18 of 23 Old 09-18-2010, 09:07 AM Thread Starter
bjjfoshizzy
Still haven't figure this out. The clicking has went from every now and then to happening almost on every start up now. Still goes away after a couple of minutes. I'm not very mechanical so I'm probably going to have a mechanic look at it.
Any other ideas on what could be causing this? I'll point out to the mechanic to check the areas mentioned above. Any ideas on how expensive this could be if it is something listed above?... or anything else?
post #19 of 23 Old 09-18-2010, 03:56 PM
hustler905
Mine was a cracked weld on one of the cats. I put a stainless clamp on it to test until I got my neighbour to weld it again.
hustler905 is offline
post #20 of 23 Old 09-18-2010, 04:02 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Is there a Fram oil filter involved? If so, try swapping it with a good quality oil filter like Wix, AC-Delco Duraguard, Purolator PureOne, etc. Frams are notorious for leaking the top-end oil back down through the oil filter's check valve which allows a dry engine start.
Jerry Bransford is offline
post #21 of 23 Old 09-18-2010, 04:52 PM Thread Starter
bjjfoshizzy
Hey Jerry... been awhile! Nope, no fram oil filter. I have a Mobil 1 filter in there right now. Any problems with those?
post #22 of 23 Old 09-18-2010, 04:55 PM
Jerry Bransford
Administrator
Hey I just noticed it's you! So you're back in SD for the surf? No problems with the Mobil 1 filter.
post #23 of 23 Old 09-18-2010, 05:21 PM Thread Starter
bjjfoshizzy
Yeah, back for the surf! Just been taking it easy and trying to find some work. Things have been good... can't complain. If you ever need a extra hand with anything, let me know! Catch you later.
engine noise , click , start-up , TJ
Jeep "Clicking" Noise at startup... evan1395 TJ Wrangler Technical Forum 10 04-24-2010 09:15 PM
Hesitation only at startup in the morning, is this normal??? chaznad TJ Wrangler Technical Forum 4 03-17-2009 04:59 PM
Rough idle on cold/first startup of the morning. abnormal TJ Wrangler Technical Forum 18 08-15-2007 10:09 AM
Valves tapping and clicking at startup? SteelBlueTJ TJ Wrangler Technical Forum 8 01-05-2005 05:38 PM
Engine Noise @ Startup WR4NGLER TJ Wrangler Technical Forum 11 09-24-2004 06:51 PM
