Engine clicking every morning after startup... - JeepForum.com
post #1 of 23 Old 07-06-2010, 10:59 AM Thread Starter
bjjfoshizzy
I heard this is common with Jeeps. It usually goes away after driving for a couple of minutes. I'm planning on changing my oil soon as was just wondering if there is anything I can add during the process to help reduce this at all? I think I recall someone mentioning replacing a quart of oil with atf? I use mobil one synthetic. Thxs.
bjjfoshizzy is offline
post #2 of 23 Old 07-06-2010, 11:03 AM
Sundowner
1. No. Don't do that.
2. Try a conventional oil.
Sundowner is offline
post #3 of 23 Old 07-06-2010, 11:10 AM Thread Starter
bjjfoshizzy
Switching back, huh? I've been using synthetic for so long... any recommendations on a conventional oil and filter?
post #4 of 23 Old 07-06-2010, 11:38 AM
LJameson
Valvoline 10w-30 conventional is a very good oil. I use that with a wix/napa gold/car quest filter and have good results. If you're stuck on the mobil brand, clean 5000 is a good oil too.
1990 YJ
LJameson is offline
post #5 of 23 Old 07-06-2010, 11:46 AM
Sundowner
There's about a thousand threads/opinions on that.
Any of the name brands are good. Unless you're in very specific circumstances where synthetic really will perform better/longer for you, then there's no reason to use it. 10w-30 dino oil will get you there. The filters mentioned above are great choices.
post #6 of 23 Old 07-07-2010, 04:52 PM Thread Starter
bjjfoshizzy
Thanks for the info... I'll give it a shot!
post #7 of 23 Old 07-07-2010, 04:58 PM
DevilDogDoc
And for all to know Kragen now carries Wix filters, since they merged with O'Reilys and Schucks and all them. I was happy to see that yesterday as before only Napa carried them here where I live and it's a 40 mile round trip there.
An ugly Jeep with some stuff.
DevilDogDoc is offline
post #8 of 23 Old 07-07-2010, 05:03 PM
durango-bob
2006 WK
Is your oil level Ok. Clicking for a while after start up can be a symptom of low oil level.
durango-bob is offline
post #9 of 23 Old 07-07-2010, 05:49 PM Thread Starter
bjjfoshizzy
Yeah, it does it even after an oil change. I don't have any leaks either.
post #10 of 23 Old 07-07-2010, 07:55 PM
hustler905
Mine was a cracked weld on a cat (right near the exhaust header). My neighbour welded a little bead on, and the noise went away. In the mean time I tested it with a pipe clamp.
hustler905 is offline
post #11 of 23 Old 07-07-2010, 08:38 PM
couesfanatic
keep us updated if you figure it out. I have the exact same noise. I'm pretty sure its the exhaust manifold.
couesfanatic is offline
post #12 of 23 Old 07-08-2010, 04:39 PM Thread Starter
bjjfoshizzy
Yeah, I just heard it was common with the engines. Hearing that you guys found some defects that might correct the problem has me thinking now. I'll check it out and post up if I can find anything.
post #13 of 23 Old 07-08-2010, 05:34 PM
Dryseals
1980 CJ7
Clicking after start-up is usually a lifter not pumping up, a push rod or a rocker. In most cases it's a lifter who's not pumping. Once the oil warms and is a tad more fluid, it pumps up and the noise goes away.
I would pull the valve cover and find which one it is. Some time the rockers are just a tad loose.
I would change the oil, oil is not going to cause this problem, it mechanical.
Dryseals is offline
post #14 of 23 Old 07-09-2010, 11:56 AM Thread Starter
bjjfoshizzy
Hey Dryseals- you recommend changing back to conventional from synthetic? I know it's not going to solve the problem but it will at least save me some cash on oil changes. Yeah, I'll have to find a bud or take it in somewhere to have them look at it. I'm not too good with the self maintenance. The problem only seems to arise on cold mornings. I've never noticed the clicking during warm weather periods.
post #15 of 23 Old 07-09-2010, 05:31 PM
Dryseals
1980 CJ7
I typed too fast, no I would not recommend going back to the dino oil, I'm a firm believer in synthetics, the protection they provide is far superior to dino oil. I work in an industry/plant who has well over 400 pumps and motors and most are over the 100 HP range. We use synthetics because they do offer better protection.
There's a lot of things that can cause an early morning tick. A valve sticking can cause the same noise. A stethoscope might help you determine where the noise is coming from, sometimes a long handled screw driver will work too.
Dryseals is offline
engine noise , click , start-up , TJ
Jeep "Clicking" Noise at startup... evan1395 TJ Wrangler Technical Forum 10 04-24-2010 09:15 PM
Hesitation only at startup in the morning, is this normal??? chaznad TJ Wrangler Technical Forum 4 03-17-2009 04:59 PM
Rough idle on cold/first startup of the morning. abnormal TJ Wrangler Technical Forum 18 08-15-2007 10:09 AM
Valves tapping and clicking at startup? SteelBlueTJ TJ Wrangler Technical Forum 8 01-05-2005 05:38 PM
Engine Noise @ Startup WR4NGLER TJ Wrangler Technical Forum 11 09-24-2004 06:51 PM
