#91 | ||
I'm currently running a stock front trackbar, which has been rubbing.
I own a JKS adjustable front trackbar, but it's not installed yet. I wonder if the JKS adjustable front trackbar would (once installed) have more clearance to the diff cover than the stock trackbar? Quote:
#92 |
pirate squirrel
- Chuck - Nth Degree 4.5" short arm the "Dude" abides |
#93 |
THE End-all, Be-all TJ alignment thread to be sure. I have learned more from this single source than any other. Thanks to you Flatlander for all the info., and to all who ask the right questions. I am subscribed. So far, I solved my Death Wobble with a $20 balance. Thanx again. BART
ifyoubegintothinkyou'relosingcontrol...it'salready gone |
#94 | ||
Now in the 937
Score!
I'm getting close to finishing the front suspension on my 1 ton TJ.. once I have it up and running and legal and inspected I'll be sure to get an alignment and post the results
The lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase Build thread here. Quote:
Pictures of it wheeling at Bill's 491 And more pics from that trip here! |
#95 | |
want it rite or rite now?
the jks has less clearance than stock, on some rigs they hit the stock covers.. click the track bar link in my sig...
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable HighLine Hood Jeepers TJ Adjustable Track bars DIY highline fenders.... 34-37's under 0"-2.5" lifts shock length, bumpstop extension, tire size chart click here DIY shock shifters, more uptravel/better ride 2011 E-350 4x4 Van conversion 2006 Rubicon Unlimited ASE Certified Master Tech/Fabricator In need of work... 11/2/11 |
#96 |
To Mudb8 and Flatlander, and anyone else:
Which aftermarket front trackbar is good and has as much, or more, clearance to diff cover than stock front trackbar? i.e. - which aftermarket front trackbar do you recommend for a 3" lift? |
#97 |
nth degree and currie are the only ones that have "as much or more"..
#98 |
Had my alignment checked out a few days ago. Checked this thread before I went. I've got -0.1 camber on the right front, and I don't consider that to be enough to require a $90 ball joint and $200 of install labor. Am I wrong? And why would I have -0.1 on a stock Rubi? Running the new 245/75/16 Wrangler MT/Rs.
#99 | |
prolly cuz the dude that checked it wanted something to do and diddn't go bang on the tire to make it read in spec.... I wouldn't worry about it.
#100 |
I'd say forcing a correction would be worse than the fix he offered. I'm only trying to estimate how often I should rotate my tires to spread the wear difference to all 4 (if possible).
#101 |
.1 degree?.... can you put that in inches?
#102 |
Approx 0.541 inches at top of tread.....I think. Let me make sure on that.
#103 | |
Now in the 937
Dude... that is ONE TENTH OF A DEGREE!!
The guy is BSing you. Chances are he would charge you hundreds to install and realign, and just push on the alignment head to make it say zero. FWIW I'd estimate that would equate to less than 1/8" camber from top to top and bottom to bottom of the front tires. The OEM spec is -1.0 to +1.0 degrees IIRC. You are dead in the middle. Perfect.
#104 |
My camber spec is -0.9 degrees left side, and -0.6 degrees right side. Just found out today. Considering adjustable ball joints to be able to adjust. My alignment guy told me that he thinks it's a borderline call if it's worth the cost of adjustable ball joints, and he thinks I could just ignore and rotate more often.
However, I think I want the adjustable ball joints. What do you guys think? |
#105 |
I now have a Rancho drop pitman arm intended for a 2.5" lift install and it seems to be OK on my 2.75" lift.
I now have my new JKS adjustable front trackbar installed and adjusted, but I don't like it because clearance to front diff cover (still the Riddler on there) looks bad. It looks to me like the front trackbar will hit the front diff cover when suspsension compresses on a hard bump. I like the looks of the Nth Degree front trackbar kit and drop pitman arm better. Looks like more clearance to front diff cover. Also looks like a stiffer and stronger front trackbar. So I'm thinking of getting an Nth Degree front trackbar kit and Nth Degree drop pitman arm (they go together) and replacing the JKS front trackbar and Rancho drop pitman arm. However, here is my concern. The Nth Degree trackbar kit and Nth drop pitman arm say they require 3" of lift or more to work. I have 2.75" of lift on front, and approx same on rear. Would the Nth Degree front trackbar kit and Nth drop pitman arm work for me? Would the Nth Degree front trackbar clear engine and front axle during suspension compression? Also, which would be better for 2.75" lift, an Nth Degree or Currie adjustable front trackbar? Last edited by CB3; 06-13-2009 at 03:27 PM.. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
