#61 | ||
I have read this thread. And am glad the OP took the time to write it. Jerry I'd say you have a LOT of experience working on jeeps. I don't. So when he breifly mentions to simply adjust the fluax capacitor I don't really know what he is talking about. ![]() This must be an easy thing to do as it is the last thing my mechanics do to either of teh corvettes before we go road racing. But with the economy hitting my business rather hard I'd like to take the time and learn how to do some of this easy stuff myself.
00 TJ 4.0 / 98 5.9 Liter Grand / 98 C5 Corvette (set up for SCCA racing) |
#62 | |
Do it right or not at all
![]() Join Date: Jan 2003
![]() Find the "Drag Link" in the below photo. On it, you'll find an adjustment sleeve held in place by two nuts and bolts, use a 3/4" wrench to loosen them. Turn that link to shorten or lengthen the drag link which will rotate the steering wheel left or right as needed until it is straight. It may take several attempts to get the wheel perfectl centered, driving it on a straight road each time to check your progress. Tighten the two nuts and bolts securely afterwards and you're done. This will not affect the rest of your front end's alignment.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#63 | |
I have only put 3,000 miles on the vehicles since I bought it. I should be getting new tires this coming week end. The uneven wear has destroyed the previous owner's selection of tires.(Four different brands of tires and five different ones.)
2004 Jeep Wrangler Unlimited, Automatic RC 2.5" Lift - RC 2.5" Rear Track Bar Bracket - JKS 1.25" Body Lift - JKS Front Disconnects - JKS 1" Budget Motor Mount Lift - Spidertrax 1.25" Spacers - Power Door Locks with Keyless Entry Build Project Thread Rocker Guard Comparison Chart - Final Differential Gear Ratios - Oxygen Sensor FAQ |
#64 |
flatlander757 I haven't been a member here long and just saw this post. Saved me a trip to get my alignment adjusted. By the way a little of topic but where do you work in VA Beach? In case I can't do something after reading this thread. Great Post.
/l ,[____], l---L -0lllllll0- ()_) ()_)-O-)_) |
#65 | |||
Now in the 937
If you set your toe going by the centers of the tires(not the fancy square tubing with wheels off setup that Jerry and MrBlaine use), make sure you check the difference in multiple spots after you set it. Get an "average" if you will to ensure accuracy. Quote:
The lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase Build thread here. Quote:
Pictures of it wheeling at Bill's 491 And more pics from that trip here! |
#66 | |
#67 |
I have an 04 tj with pull to the left. checked presures on tires and tried rotating NO HELP. Had alignment shop check it out and replace front worn track bar they found was bad STILL NO HELP. Read a thread on here the other day that was pointing to UCA or LCA front or rear. Inspected without help (dont know if thers is any play) but did find that the bushings apear to be dry rotted and no damage to any components. Also measured wheel base and found drivers side at 94 inches and pass at 93 dont know if that indicates anything. Wondering if you or anyone has any ideas on what I can do to fix this. GREAT ARTICAL ALSO
#68 |
I think I see a line...
Ok I got one for ya. I had my Jeep aligned recently after getting new tires and just to have it checked since it's been awhile. Now this is a reputable shop and they have done lots of work for me and never done me wrong but here's what he came at me with.... " the front was fine other than the toe being out quite a bit but it's the rear that has me worried. It shows the tires to be leaning like this \--o--\ and it needs some work or you'll get bad tire wear on the outside of one and the inside of the other." Now this is a straight axle I say and how can that be and how do you plan to adjust this? "Well theres a shim we can put behind the backing plate to change this to meet specs" This is a Dana 35 so I'm not going to put any money in it but how can this be and I see no way to change the tilt of a rear tire when there are bearings on the end of the axle shafts. Is this correct or not?? Like I said I don't plan on putting money into it but I don't see how this scenario is possible.
2004 Wrangler X, 6-cylinder, 5-speed, Dana 30 w/ARB, Alloy USA front shafts, Dana 35, 2" BB, 1" BL, OME shocks, Brown Dog MML, UCF Ultra High-Clearance Skid, Lo-Pro Mount, SYE, Pro Comp Adj. Control Arms, Savvy Gas Tank skid, JKS Quick Disconnects, Rock Hard Sliders, 31" BF Goodrich KM2's on Ravine wheels, Hard Top, Bestop Soft-top, Bestop Safari Top 2010 Moab Trip Thread with JeepForum Members http://www.jeepforum.com/forum/f95/idaho-jeep-moab-2010-a-1038859/ |
#69 | |||
Now in the 937
Accurate wheelbase measuring is kind of hard with tires on the vehicle, having the wheels just slightly off-center can make one side look bigger than the other. Now the dry-rotted bushings... are they like that on only one side? Can you post the alignment specs? Quote:
Honestly when it comes to camber, you should be able to eye-ball it pretty close to +/- 1.0 degrees of 0. If it physically looks straight up and down, chances are it's within 0.5 degrees of 0 on each wheel. I wouldn't hesitate to assume they were trying to make a quick buck on a BS labor and part charge. It's easy to fool the machine by not having the rack dropped onto it's locks, or even individually messing with the alignment heads(ie: pushing in on the top of one and bottom of the opposite head) to throw the camber reading off. You're correct in saying there is no way to tilt the wheel mounting surface in relation to the axle. This is done on a lot of FWD cars with a "solid-like" rear suspension assembly. Such as found on older Jettas, Neons, PT Cruisers, Caravans, Cobalts, etc etc. Angled shims are used for toe and camber adjustments on those cars if they're way out of spec. Had a 2002ish Jetta the other day that had +0.22 toe in in the LR, and -0.87 toe out in the RR Of course the customer chose the cheap route in buying shims as opposed to getting the entire solid "member" for the rear.In a nutshell whoever told you about the shims for a solid rear axle doesn't know their a** from their elbows. Did they try to quote you parts and labor for that? I'd try and put their asses out of business.
#70 |
Just seems to be the LCA bushings that are dry rotted. And here are the alignment specs left caster is 6 9/16 deg , right caster is 6 5/16 deg , left front camber is -1/2 deg , right front camber is 1/8 deg , left front toe is 5/16" , right front toe is -1/32" , total toe is 9/32" , left rear camber is -19/32 deg , right rear camber is -9/32 deg , left rear toe is 3/32" , right rear toe is 1/8" , and thrust angle is -1/32 deg
#71 |
Flatlander, I was under the impression that when upgrading past a 31" tire... Say a 33 that you need to have toe slightly less then factory spec. (IE: +9 per tire = combined +18 rather then +30 like factory spec calls for) Is this true?
#72 |
wow great thread, nice job flatlander. thanks a bunch.
I just read the whole thing, but i'm still confused on some things. I'm installing a 2.5" OME soon: 1. Caster will be off a little, but I can't afford adjustable UCA's right now, so theres nothing I can do. 2. my front tires are cupping, so i've already got excessive toe in. 3. when doing a DIY alignment to set the toe in after the lift, what do I use to measure in 1/32nd of an inch? I can't imagine a tape measure is accurate enough, or is it? I read the write up on 4x4xplor, but I've seen another method using rods attached to the wheels to measure toe. Any comments about this? When you measure the toe front to back using either the tire as on 4x4xplor, or the tube/rod method, what type of difference should I be looking for front to back? Is a tape measure actually accurate enough for this? Another question - is there any benefits/negatives to running excessive caster with larger tires? like 7* with 35s? or 7* with 33s? (Ignoring pinion angle) Will this make the jeep more stable on the highway, or any other benefits/negatives?
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#73 |
...deleted...
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? Last edited by Unlimited04; 03-27-2009 at 06:30 PM.. |
#74 |
...deleted...
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? Last edited by Unlimited04; 04-11-2009 at 10:20 PM.. |
#75 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
