The "End-all, Be-all TJ Alignment thread" (LONG read)
#46 | |
i have a 1999 TJ with a six inch rough country lift and 2 inch body lift. I got it aliegned and the shop said i need a bottom ball joint that is adjustable for more adjustment ?? Where may i get this...
#47 | |
Never Forget
i was trying to tell you in your other thread you dont need them unless your axle is bent, i would try second shop,
http://www.jeepforum.com/forum/f9/need-camber-adjust-there-adjustable-ball-joint-avail-431117/?highlight=ball http://www.jeepforum.com/forum/f9/adjustable-ball-joint-fixing-bent-axle-323195/?highlight=ball looks like a mopar part
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers Quote:
www.cityprofile.com |
#48 |
Great thread flatlander. I am very interested in how the SAI, caster, camber and toe interealation ship affects us on our modified vehicles. Specifically:
-If you were to order a new front axle assembly from say Currie for your lifted TJ and you wanted to rotate the pinion angle to some setting, would you have them still set the knuckles for a caster of 7 degrees? Or should that number be different due to larger tires, different wheel offsets etc? -If you took an axle from say a 1979 F150 and stuck it under your jeep, should you weld the brackets on such that you used the alignment specs from the Ford truck or from the Jeep (ie let's say the Ford called for 3 degree caster vs the jeep 7 degrees for example)? I'm guessing you would set it to the Ford specs since that would be how the contact patch was engineered?
97 TJ Sport OPJ project (other peoples junk) I can't remember the last time I bought a new part. |
#49 | ||
Now in the 937
2. Again it depends on the tires entirely. The stock Jeep specs mean nothing since they're likely not going to be used with 30" tires. And the Ford specs don't matter much either as the axle won't be used in the same application or with the same tire size. The contact patch was engineered for maybe 31" tires(whatever the F150 in question had stock). It won't be used with that small of a tire I'm guessing so it's a moot point. Once you get into crazy modifications it gets to a "whatever works" sort of deal. From 30s to 31s 7 degrees is acceptable. 35s favor 5 degrees, so 33s fall somewhere in the 6 degree area I'm speculating. After that, let it eat and hope for the best ![]()
The lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase Build thread here. Quote:
Pictures of it wheeling at Bill's 491 And more pics from that trip here! |
#50 |
Thank you for this thread.
#51 |
Edit found answer
#52 |
Grunt......
Camber & Adjustable Upper Ball Joints?
I've noticed not normal wear on the insides of my front MTR 35x12.50's so after rebalancing I took her in for an alignment and was told my camber is way off with both upper ball joints and they could not fix the problem without a replacement with adjustable ball joints ? WTF ? Ideas?
#53 |
Do it right or not at all
![]() Join Date: Jan 2003
Yep, the TJ's camber angle is not adjustable without installing adjustable ball joints. I can't imagine the camber angle being off that much with such a new TJ though unless you've been jumping it out in the desert. Maybe a second opinion is needed on that. Does your TJ's camber angle look ok from the front?
And a big welcome to JF Semprfimac... always happy to have the Marines here!
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#54 | |
Now in the 937
Either something may be bent(axle) or the alignment rack isn't/wasn't level. Got the alignment print-out specs on hand?
If one side is way positive and the other is way negative(ie: +0.5 and -0.5) then chances are the rack wasn't level and the guy didn't know what he was doing or they did it on purpose trying to make you buy stuff as everyone's hurting for money now.
#55 |
Grunt......
Jerry, you nailed it, I have been jumping her out in the desert in a place called Glamis dunes. I do have a friend who works at a Jepp shop so I'll have him check it out as well but in case I do need to purchase new joints, Any ideas on vendors or models for these ball joints?
And thanks for the welcome aboard ! OooRaahh ! |
#56 |
I don't know of a particular brand of adjustable ball joints Semperfimac but if your local auto parts store does't have a good recommendation, you can get them from your Jeep dealer's parts department. But you may have to have them order them as they may not stock them.
#57 |
I hope the alignment people here could give me some advice. I am getting excessive camber wear on the outsides of my front tires.(Positive Camber) I am fairly sure this would be a sign of worn ball joints, correct?
If it had wear on the insides of the tires that would make sense the axle was bent upwards. Bending the axle downwards would be fairly difficult.
2004 Jeep Wrangler Unlimited, Automatic RC 2.5" Lift - RC 2.5" Rear Track Bar Bracket - JKS 1.25" Body Lift - JKS Front Disconnects - JKS 1" Budget Motor Mount Lift - Spidertrax 1.25" Spacers - Power Door Locks with Keyless Entry Build Project Thread Rocker Guard Comparison Chart - Final Differential Gear Ratios - Oxygen Sensor FAQ |
#58 | |
Now in the 937
I'd say check your toe-in first and rotate tires frequently. Normally when a balljoint wears the tire will tilt inwards(negative camber).
I suppose it's possible to bend an axle goofy upwards, but the chances of that are pretty slim IMO. The excessive wear on the outside can be caused by a lot of toe combined with lots of city driving/turning. When you go around corners the outside of the tire will grip more as weight is transfered to the outside front wheel. What kind of tires? How long since rotated? I rotated my Swampers every 3k miles and with 22k miles on them they wore real evenly and still have about 8k miles of good usable tread life left.
#59 |
How does your average Joe set his steering wheel alignment on a 2000 stock TJ? Will I throw everything else out of whack?
00 TJ 4.0 / 98 5.9 Liter Grand / 98 C5 Corvette (set up for SCCA racing) |
#60 |
Should we take that to mean you didn't bother reading the thread before asking this?
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
