The "End-all, Be-all TJ Alignment thread" (LONG read)
#16 | |
Brake Wizard
We need to tune it up slightly before it goes there.
I am Savvy I am handling the sales of Black Magic Brakes on www.blackmagicbrakes.com |
#17 | |
Brake Wizard
Great work though.
#18 | |||||
Now in the 937
Awesome, thanks!
Thanks! Quote:
I noticed in your thread you had no mention of swapping tires left to right. Try doing that with the front first, then if that doesn't do anything try it with the rear too. Aside from worn control arm bushings(could be any 16 of them), I don't see anything else that could cause it. This theory is sort of "out there," but I suppose if your rear axle was bent on one side, the camber would be out of whack. Based on your left side tire wearing even and the right side wearing on the outside, it sounds like the camber is in the positive on the right side(how that would happen I do not know). Since the side that has more positive will cause the pull in the front, in the rear it would have more "leverage" in relation to the left(contact patch is further to the outside of the axle housing) and also the left side would have more drag(larger overall contact patch). It wouldn't be detectable just cruising or in decel because the front primarily accounts for the vehicles habits in those conditions, but under accelleration the rear axle sees weight transfer. This is just speculation of course. You can buy an angle finder real cheap, jack up the rear axle and remove wheels. With the drums/rotors FLAT against the axle shaft, you can check the angles in relation to each other. You can even check the angles of your axle tubes in relation to each wheel-mounting-surface angles. This is the cheap way, but an alignment wouldn't be a bad idea at this point. Thanks! I guess I wasn't chillin' in my jammies eating Cocoa Puffs for nothing this morning Quote:
![]() ---------------------------- Going back to caster and camber, another measurement that the alignment machine may give you is steering axis inclination. ![]() Steering axis inclination - This is the angle that runs through the centers of your ball joints down to the ground when viewing it from the front of the vehicle(same way you view camber). Do NOT get this confused with camber, it is the angle of the wheels in relation to each other, SAI is through the ball joints to the ground. While the angle itself isn't necessarily important, where it lands on the ground is. It ideally will end up right in the center of or slightly inside of the contact patch of the tire, resulting in a small scrub radius. ![]() The scrub radius is measured from the tire centerline to the point on the ground that intersects the SAI angle. This should be an inch or two wide ideally(from what I have gathered). Any more would cause excessive steering effort/feedback and too close to zero kills nearly all feeling of the road causing a few unstable feeling. It is the single point of SAI on the ground that the tire actually wants to pivot on. Or the pivot radius. ![]() The scrub radius and pivot radius are affected by larger tires and aftermarket wheels with [numerically] less backspacing. I'm not necessarily sure as to whether TJs have a positive or negative SAI in stock form, I would have to guess positive(SAI intersects ground OUTSIDE of center of tire contact patch). Mainly because that is pretty much the norm for every vehicle I've seen. Reason that the pivot radius is generally on the OUTSIDE of the tire contact patch center line is because the road will not have as much leverage on the wheel. Also should a brake caliper sieze on one side, a positive scrub radius/pivot radius will transmit less force back through the steering wheel. In general both positive and negative have the same effects on steering stability and feel, except negative SAI will result in more feedback and will be more likely to follow imperfections in the road. It is possible that with small tires(30") and aftermarket wheels(say less than 4.5" of backspacing) that you would be putting steering stability in jeopardy; reason being as you are moving the wheel centerline outwards, the SAI stays the same, and keeping tires the same or similar diameter, causes a smaller scrub radius. The scrub radius should remain fine provided you have larger tires AND less backspacing to keep the steering pivot point similar in relation to the tire centerline. Now that I think about it, this also explains why my TJ on 33" tires w/ stock offset(5.5") wheels has a relatively strong return to center feeling in comparison to stock TJs. For all intents and purposes, the SAI is not adjustable. Here is an excerpt from my 03 TJ FSM: Quote:
The lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase Build thread here. Quote:
Pictures of it wheeling at Bill's 491 And more pics from that trip here! Last edited by flatlander757; 01-05-2009 at 05:16 PM.. |
#19 | |
I've pulled and checked all the rear CA's, all of them are tight and not worn. The only loose component I have found is the sway bar. http://www.jeepforum.com/forum/f9/rear-sway-bar-bushings-655559/#post6255658 The bushings look a little loose to me, and the pass side is lower by about an inch. Think that could be contributing?
Air Force Jeep Club - Tail# JF037AD '03 TJ Sport, Black on White, Stock. [[Gone]] '99 XJ, Purple, Stock but with new wheels. Running Doorless? Check your state's Mirror Laws!! http://www.jeepforum.com/forum/f176/list-state-mirror-laws-565361/ There can be no fifty-fifty Americanism in this country. There is room here for only 100% Americanism, only for those who are Americans and nothing else. Theodore Roosevelt |
#20 |
So i have really weird tire wear on my 32's so they are 32x1150 on stock caynon wheels with 3" of lift. The outer edge is wearing alot faster than the rest of the tire is. no pull or any thing involved. I did purchase these tires used and they were worn like this when i got them but not nearly as bad.
Just Empty Every Pocket JEEP. . . It's big, It's slow, It's clumsy, it sucks on asphalt, and I love it. SHORTBUS...YAY IM SPECIAL!!! eugenethejeep: my mom was in here talking and being weird lol. i don't think her seeing us talk about cat tacos would be appropriate 35's and a lift kit how stuck can you get? - Justin Moore |
#21 | |
Now in the 937
dz1087: The swaybar isn't an "essential" part of the suspension, but it being bent will preload one side vs the other. Try pulling your rear swaybar entirely and drive it.
If you've done that and tried swapping tires left to right, and still nothing, I need to see some alignment specs for the whole vehicle to see if something is bent. saharaTJ7638: Which tires are wearing fast? It's possible you have your toe set too far in causing feathering and accellerated wearing of the outter edges. Follow the write-up on www.stu-offroad.com for just setting toe in your driveway.
Pictures of it wheeling at Bill's 491 And more pics from that trip here! |
#22 |
Going in my jeep tj bible ----- Thanks for the info!
A person once told me i was driving beyond the capabilities of my vehicle - obviously they never seen the capabilities of a jeep! This space saved for info: |
#23 | |
Brake Wizard
#24 | |
I took off the sway bar - it rode a little smoother, but still pulled. Swapped the tires out, still pulled. I measured the wheel base about 3 weeks ago and both sides came out to 93.5", so I think it has to be dynamic loading of some sort. About the only thing I haven't swapped to the other side are the UCA's. I had an alignment done in September, but did not get a print out.
Air Force Jeep Club - Tail# JF037AD '03 TJ Sport, Black on White, Stock. [[Gone]] '99 XJ, Purple, Stock but with new wheels. Running Doorless? Check your state's Mirror Laws!! http://www.jeepforum.com/forum/showthread.php?t=565361 There can be no fifty-fifty Americanism in this country. There is room here for only 100% Americanism, only for those who are Americans and nothing else. Theodore Roosevelt |
#25 |
I just swapped my UCA's. Still pulling to the left.
#26 |
This page has been bookmarked.
#27 | ||
Now in the 937
Technically it's not the SAI that points in front of the tire, it's the caster angle(SAI is viewed from the front of the vehicle, caster is viewed from the side). These angles are each laid out in two separate dimensions(think of SAI on running along the X and Y axis, and caster on the Y and Z axis in 3 dimensions).
While I can't explain the scientific reasoning with numbers and formulas and stuff(I'm sure you know though), it works the exact opposite way that shopping carts' front wheels are set back. The shopping cart has it's wheels set behind the pivot's centerline as it is the cart that determines where the wheels go. In vehicles, it is the wheels that we need to determine where the vehicle goes(ie, the vehicle shouldn't control what the wheels do). Because of this, the caster is set to put the wheels' pivot radius in front of the axle and tire contact patch centerline. Ever ride a bicycle with the handlebars turned backwards? It is much less stable and it makes it far more difficult to ride with no hands. I see it like this: the weight of the vehicle is supported by the front and rear tires. With the caster pointed behind the contact patch centerline, the vehicle weight makes the front wheels want to pivot about the steering axis causing instability. With the caster pointed in front of the contact patch centerline(like it is supposed to be), the vehicle weight keeps pressure on the steering axis, and with the caster behind, it is naturally going to want to self-correct steering itself to some degree. Kind of hard to explain, but from the side, draw a triangle from the upper ball-joint, to the tire contact patch centerline, and to the point on the ground at which caster intersects. The weight is supported by the ball-joints, and thus is transferred to the wheels through them, so with the weight being pushed from the upper balljoint to the caster/ground point, you can see why a super low caster angle would want the steering axis to rotate about itself. Quote:
Yeah you need an alignment print out in order to see what may be going on. If any of the control arm bushings were worn, they SHOULD have produced the pull in the opposite direction when switched. With that said, track-bar bushings are pretty cheap and relatively easy to replace. You could try replacing those first(even if they look good). I fail to see how the trackbar bushings would produce a pull though, as it's only job is to keep the suspension under the vehicle and should have no real effect on thrust angle. I'd like to see what your rear camber and thrust angles are in particular.
#28 |
Semper Fi
Super write up,
Mods, any chance for a stickie? Should be. Again, thanks.
Skyryder Proud user of the "K.I.S.S." Principle.'97 Black TJ - 4 banger - 5 speed Black Jeep Society #264 |
#29 |
Junior Member
Thanks for taking the time to do this write up. It now makes sense.
#30 |
Great write up! Belongs in the FAQ in case it hasn't been said enough.
Question about toe in. When you say TOTAL toe and give the factory spec of +0.30 degrees +/- 0.06 degrees. Is that saying one wheel is straight and the other is +.30 degrees inwards? Or are both wheels angled 0.30 degrees inwards. I'm relating this to larger tires and setting the toe with a tape measure. It appears larger tires hardly effect what you would measure. For a 30" tire I got 0.157" of toe in. For a 35" I got 0.183". So a little less than 1/32" difference for a 5" tire size increase. Sound correct? |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
