The "End-all, Be-all TJ Alignment thread" (LONG read) - Page 17 - JeepForum.com
post #241 of 291 Old 10-04-2012, 07:16 AM
SideshowBob024
Can we discuss Caster and backspacing?
Somebody brought it up that because my Craigslist special wheels have less backspacing to allow 35x13.5's some more space. How does this effect what I want to do with Caster? This person indicated it may have an impact and I was trying to think it out in my head and failed.
SideshowBob024 is offline
post #242 of 291 Old 10-04-2012, 09:20 AM
familyTJ
Great thread. Going to try it myself this weekend.
familyTJ is offline
post #243 of 291 Old 10-04-2012, 11:18 AM
biffgnar
biffgnar's Avatar
This doesn't make any sense to me. You haven't changed the location or orientation of the wheel mounting surface at all. In fact, isn't one of the ways advocated in this thread for doing the alignment is the wheels off with metal rods strapped to the mounting surface? That method would take the wheels completely out of the equation.
Romney in 2020!
biffgnar is online now
post #244 of 291 Old 10-04-2012, 11:25 AM
SideshowBob024
That's what I said. His argument was you changed the center of where the tire touches the road and henceforth changing the imaginary line where the caster "line" hits the road. I didn't buy it but I figured it was worth posting if for no other reason then to make sure I don't need to change anything.
post #245 of 291 Old 10-06-2012, 03:35 AM
SpeedJeep
SpeedJeep's Avatar
Someone needs to check the definition of caster. He might mean camber but that's not adjustable without buying special ball joints.
With sufficient thrust, pigs fly just fine.
SpeedJeep is offline
post #246 of 291 Old 10-08-2012, 08:16 PM
TheRealKTrain
JK Wrangler
This is for you, Slackjaw
"We are what we repeatedly do. Excellence, then, is not an act, but a habit." Aristotle
Μολὼν λαβέ
TheRealKTrain is offline
post #247 of 291 Old 10-09-2012, 08:50 AM
SlackJaw
baby jeep
SlackJaw's Avatar
lol, thanks honey!
just came to read, but I'll go ahead and ask in this post...
When we say (arbitrarily) 1/4" toe in....
Are we saying line up to 0" neutral toe, and then adjust the front 1/4" shorter?
Or are we saying a differential between the front and back measurement of 1/4" (I suppose which would be effectively +/- 1/8")
Gonna go read now.
SlackJaw is offline
post #248 of 291 Old 10-09-2012, 08:54 AM
SlackJaw
baby jeep
SlackJaw's Avatar
okay so according to the link to the write up in the OP, it is the second of the two:
"Continue this process until the width in the front is about 1/16" (but no more than 1/8") closer together than the back."
Anyone care to confirm or refute?
Thanks!
SlackJaw is offline
post #249 of 291 Old 10-09-2012, 08:58 AM
biffgnar
biffgnar's Avatar
Originally Posted by SlackJaw View Post
lol, thanks honey!
Gonna go read now.
Been awhile since I read this whole thread, but I look for difference between front and back of ~ 1/8". I don't think either of the options you suggested are that.
Romney in 2020!
post #250 of 291 Old 10-09-2012, 08:59 AM
SlackJaw
baby jeep
SlackJaw's Avatar
perhaps I used the word "differential" incorrectly, but yeh, that is what I meant.
SlackJaw is offline
post #251 of 291 Old 07-28-2013, 09:46 PM
fasttrucks
ok i want to add a heavy duty tie rod bar and new tie rods to my 2002 tj do i need to get it alined or can i just set my tow that i have now which is a half inch when i take the diffance bewteen the measurement in the front of the tire and the rear of the tire ?
fasttrucks is offline
post #252 of 291 Old 07-29-2013, 09:15 AM
biffgnar
biffgnar's Avatar
All you need to do is reset toe, but 1/2" is not right.
Romney in 2020!
post #253 of 291 Old 07-29-2013, 09:50 AM
mike_dippert
mike_dippert's Avatar
The factory spec limits, with your 32" tires gives the following range:
0.201062-0.134041 or
3/16 - 2/16
mike_dippert is offline
post #254 of 291 Old 03-16-2014, 04:34 PM
MudCrud
Thanks for all the help guys. I am doing a transfer drop Monday to hopefully solve my small vibe issues.
MudCrud is offline
post #255 of 291 Old 03-16-2014, 11:16 PM
bbradUSMC
Why? MML is a better option.
Live Free,
Brad
bbradUSMC is offline
Rubicon Express/Mopar 4.5" Long Arm vs Teraflex 4" Long arm, which one is best? SaharaBlackNo1 JK Wrangler Technical Forum 20 04-24-2010 12:39 PM
The "End-all, Be-all TJ Summer thread" (LONG read) RnEmOvr TJ Wrangler Technical Forum 12 04-22-2010 10:33 PM
Alignment Specs with 4" RC lift and 1" Boom shackles Walnutz YJ Wrangler Technical Forum 10 01-19-2010 05:42 PM
My license plate should read "MNYPIT" Shinner YJ Wrangler Technical Forum 5 08-31-2004 12:19 PM
