Empty radiator but full reservoir - JeepForum.com
post #1 of 10 Old 04-25-2015, 08:38 AM Thread Starter
jcg1004
I have a 2003 TJ 4.0 and I noticed I was running hot. I checked and the reservoir was completely empty and so was the radiator. I filled them both back up and everything was fine. However from time to time I could smell radiator fluid. I initially assumed it was due to some of the fluid I spilled when I was filling it up and the spill was burning off. However after about a week the smell was peaking my curiosity so I checked the fluids again. The reservoir was completely full but the radiator itself was almost empty.
There are no visual indications of any leaks.
Any ideas?
jcg1004 is offline
post #2 of 10 Old 04-25-2015, 09:37 AM
Red Rubicon
Replace the radiator cap and when you refill the radiator be sure you purge all of the trapped air.
Red Rubicon is offline
post #3 of 10 Old 04-25-2015, 10:32 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Yep could be nothing more than a bad or loose radiator cap. Make sure the replacement cap has the proper 18 lb. pressure setting.
Jerry Bransford is online now
post #4 of 10 Old 04-25-2015, 10:32 AM
Raist11
Raist11's Avatar
Perhaps I'm crazy here but... Initially if you found your radiator and reservoir to be empty.. there should be a leak somewhere?
Current: '00 TJ Sport
Past: '98 TJ Sport - lots of aftermarket
Raist11 is offline
post #5 of 10 Old 04-25-2015, 10:51 AM
The_'ster
Start by replacing the radiator cap and check for any external leaks. Another possibility is if the head gasket has a slight combustion leak it could be forcing combustion gasses into the cooling system and the coolant into the radiator, or coolant leaking into the cylinders or the engine oil, so check the oil for contamination also. A shop should have a cylinder combustion gas detector kit to sniff the coolant.
'98 TJ has been under the knife the last 30 months getting a new frame, torque boxes and fenders.
The_'ster is offline
post #6 of 10 Old 04-25-2015, 11:25 AM
vosevichs
If you find no external leaks. I believe the 0331 head ran till 03. This head has a tendency to crack. Check the oil level. Make sure your crankcase isn't full of water.
Scott Vosevich
vosevichs is offline
post #7 of 10 Old 04-25-2015, 11:38 AM
EricsGreen98Tj
If your not finding antifreeze (radiator fluid. ) puddles then it sounds like you do have a head gasket leak or a cracked cyl head.
Defiantly replace you radiator cap and fill your radiator up. Also when you do get the radiator almost all the way full squeeze your upper and lower radiator hoses, with the cap off, to see if you can get any bubbles out (trapped air).
Check it the next day after driving, while the engine is cool, to see if it needs topped off or if you've lost any antifreeze. DO NOT WAIT ANOTHER WEEK.
Also check your oil to see if there is water/antifreeze in it. It will look soupy and white in color.
Also look at you exhaust while the Tj is running. Does it look like steam is coming out your tail pipe? If so the you've got a problem.
Building my junk with more junk, so Im always on the look out for more junk....Free to cheap preferably. :D
My junk http://www.jeepforum.com/forum/f22/survivor-project-driveway-frame-swap-33s-build-1280626/index3.html
EricsGreen98Tj is offline
post #8 of 10 Old 04-25-2015, 04:21 PM Thread Starter
jcg1004
Thanks for everyone's help and expertise. I checked the dip stick and the oil looks normal to me. After the engine cooled I removed the cap and started the engine. I watched as the water level rose over the top and spilled out. However I didn't see it bubble up. Hopefully that is a good sign.
I ended up buying a new cap and I'll run it and check it periodically. Hopefully that's all it is.
Thanks again and I'll update again if it's not the cap!
jcg1004 is offline
post #9 of 10 Old 04-25-2015, 09:05 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Remove the fill cap on the valve cover and look for signs of water contaminated oil buildup. If it doesn't look like the oil on your engine dip stick and has a white/yellow goo on it, you're leaking coolant into your oil...
Knuckelhead is offline
post #10 of 10 Old 04-26-2015, 06:28 AM
vosevichs
Good deal, cracked head sucks
Scott Vosevich
leaking coolant , overheating , radiator , reservoir , tj
