Emergency Brake Problems!!!! - JeepForum.com
post #1 of 11 Old 10-11-2010, 08:37 AM Thread Starter
SoonerDad
I am fed up with my emergency brake. I bought the Jeep back in July. The emergency brake worked. Slowly it got worse. Now, no matter what we do, we cannot get it to work.
2001 Jeep Wrangler Sport
2004 Jeep Wrangler Rubicon Danna 44 Front/Rear Axles
previous owner replaced driver and passenger cables with 2004 Rubicon Cables a short time back
The pads were replaced when a shop found leaking wheel bearings, but did not fix it
Then the cable from the consule was replaced, and it held, but not that well, but quit by the time I got home.
Any ideas??? It should be simple. What else can I replace or adjust. Chilton's is not clear about disc brakes... Thanks!
SoonerDad is offline
post #2 of 11 Old 10-11-2010, 08:48 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
The parking brake uses shoes, not pads and they adjust just like shoes in drum brakes. Adjust them until you can barely turn the tire by hand, go for a slow drive about a block or so in length and while doing that, apply the parking brake by hand so it drags. That will help to bed the shoes to the inner drum.
Take it back and adjust the shoes again until they just drag when you turn the tires by hand. Then and only then, use the cable adjuster to take out the slack in the cables. All of that will net you a parking brake that just about fully applies 3 clicks up.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #3 of 11 Old 10-11-2010, 09:47 AM Thread Starter
SoonerDad
The shop says they have done that, but I am going to take your response to them and say follow this. If not, I will do it myself. I took it to a shop to save time....
Thanks!
post #4 of 11 Old 10-11-2010, 09:50 AM Thread Starter
SoonerDad
I should mention that they even put a 1 or 1/2" spacer on the cable from the consul. I hope that has not been destroyed. Maybe the previous owner ruined the cables by not adjusting them correctly. hmmm.....
post #5 of 11 Old 10-11-2010, 09:59 AM Thread Starter
SoonerDad
Would the 3" Suspension and 1" body lift affect the cables?
post #6 of 11 Old 10-11-2010, 11:46 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Not in the least.
I am Savvy
post #7 of 11 Old 10-11-2010, 11:47 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
A possible scenario is the PO kept adjusting the cables until the shoes are gone. What may need to happen is new shoes installed, bedded, and then adjust the cables.
I am Savvy
post #8 of 11 Old 10-11-2010, 12:09 PM Thread Starter
SoonerDad
It is working now! We still have the spacer in on the adjusting bolt, but it works on 3 clicks! Right now we are thinking the 2004 bracket was located in a different place from the 2001.
Thanks for your help!
post #9 of 11 Old 10-11-2010, 01:13 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
It's in the same spot I believe, I think it's either shorter or the cable from the handle is different. I've had to put the spacer on as well when swapping to the Rubi cables for some and not for others.
It may also be they changed the cables at some point. Typically around here they try to get a VIN to sell the cables which leads me to believe there are a couple of different versions. Not sure though.
I am Savvy
post #10 of 11 Old 10-11-2010, 02:58 PM
Wimpstert
If I park on a hill with the rear of Jeep on the low side the Jeep will roll with only the E brake on but if the front is on the low side she doesn't roll....could this be the same issue mrblaine?
Wimpstert is offline
post #11 of 11 Old 10-12-2010, 04:01 PM
Phreak480
some of the hill issue has to do with the shoes grabbing better in 1 direction than the other. its an unfortunate reality of drum brakes
Phreak480 is offline
Emergency Brake odwaud TJ Wrangler Technical Forum 21 05-17-2008 06:36 AM
emergency brake Crunchakah TJ Wrangler Technical Forum 14 04-13-2008 08:35 AM
Emergency brake ??s docneon YJ Wrangler Technical Forum 5 04-20-2007 01:48 AM
Emergency Brake JFrank1968 TJ Wrangler Technical Forum 10 09-16-2006 01:13 PM
Emergency brake problems for all to read(recall) NOVA Jeeper56 YJ Wrangler Technical Forum 9 02-14-2002 02:41 PM
