Ok when I turn on my left turn signal my odometer read out also blinks. I have replace the multifunction switch allready. anyone know where to look next?
It's got to be a blinker fluid leak. That's the only thing I can think of. I heard if it leaks it can cause other things to blink, too. Also, check your blinker fluid pressure.
Seriously though, I have no idea. I'm just trying to be funny
like i said, if there is a problem with a ground, that could cause this.
It'll just ground through the easiest path it can find. Causing silly things to happen, like my non blinking blinker. Sorry, I'm not too savy with really technical electrical stuff. I just know some basics, and I have had people tell me it's a ground problem.
That is nothing more than the turn signal lever not returning fully to its center position after completing a turn. A nudge on the turn signal lever towards its center position when this happens will cure the brake illuminating the left turn arrow.
To quote Genesis "there must be some misunderstanding"
The problem is that when I signal, if i press the brake it stops blinking but remains on. As soon as i release the brake it starts blinking, and when I complete the turn it snaps back like normal.
That's a slightly different symptom then. That sounds exactly like a missing or very weak ground. I'd inspect all of the turn signal sockets for corrosion and/or a bad ground wire connection between the socket and the tub.
The other problem I mentioned of the turn signal light illuminating when the brake pedal is stepped on is the turn signal switch problem... a different issue.
...The problem is that when I signal, if i press the brake it stops blinking but remains on. As soon as i release the brake it starts blinking, and when I complete the turn it snaps back like normal.
Make sure the 4-way flasher lever is all the way "Off". My '00 would act like this sometimes. I'd give the lever a nudge to the right and things would straighten out. Would usually do it after I'd had the flashers on but sometimes it would just do it on its own.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
