Electrical problem - need help - JeepForum.com
post #1 of 7 Old 05-26-2010, 03:01 PM Thread Starter
flcrtchrckt
I have a 99 Wrangler TJ - most times when I start it the radio, turn signals, windshield wipers don't work... sometimes they do. If I turn it off and restart it a couple times it will eventually all work. Its all or none. The items listed are not on the same fuse, the fuses are fine. Any one else have this problem or know what I need to fix it? Thanks!
flcrtchrckt is offline
post #2 of 7 Old 05-27-2010, 01:12 AM
RockMonster
check your battery connections... maby a bad ground??? dose it start all the time??
God... my spelling sux.... +++++++++++++++++++++++OIIIIO+++++++++++++++++++++ ++++
RockMonster is offline
post #3 of 7 Old 05-27-2010, 04:37 AM
JEK3
JEK3's Avatar
Look inside the fuse box (not just under the cover, but actually inside it where the buswork is - you may need a screwdriver, and you will definitely need to disconnect from the battery). You may have a loose/broken/corroded bus bar.
JEK3 is offline
post #4 of 7 Old 05-27-2010, 07:43 AM
Curly5759
It is your ignition key not returning to the 'run postion, a fairly common problem on wranglers. Next time it happens, try nudging the key back towards off just a little, and everything will power up.
I squirt a little powdered graphite into the lock cylinder and work the key back and forth. This fix is usually good for about 3-5 months each time.
Curly
I start what I finish!
77 Jeep Cherokee S
97 Jeep Wrangler
Curly5759 is online now
post #5 of 7 Old 05-27-2010, 10:24 AM
kloppk
Curly
Ditto....
Very common problem.
Freaked me out the first time it happened to me
kloppk is offline
post #6 of 7 Old 05-27-2010, 10:33 AM
gmaus
There is a good chance it is the two plugs that plug into the back of the dash aren't making good contact. Pull the dash clean the contacts on it and on the plugs. Since I did that the problem has not come back. I do believe there is a write up on this.
gmaus is offline
post #7 of 7 Old 05-27-2010, 11:44 AM
bruteboy
I think these items use a common ground in the engine compartment near the headlights
bruteboy is offline
electrical
Electrical Problem - JK Suncat JK Wrangler Technical Forum 14 12-24-2007 07:11 AM
Electrical Problem...NEED HELP please! TJ-Tera TJ Wrangler Technical Forum 7 11-20-2006 09:27 AM
New YJ with electrical problem dieseldogpi YJ Wrangler Technical Forum 2 08-11-2006 07:33 AM
Electrical Problem -- What Do You Think? zudnick YJ Wrangler Technical Forum 5 04-07-2006 10:48 PM
electrical problem trw YJ Wrangler Technical Forum 2 08-06-2005 07:55 PM
