electrical nightmare - JeepForum.com
post #1 of 5 Old 11-05-2012, 07:00 PM Thread Starter
HighOutputTj
I need some serious help here. Im having an issue with my ignition, heat, and some other things. I'll try to describe as best as i can.
The first issue is my ignition, specifically starting my heep. The key will not start the engine and i had to wire in a push button to jump the terminals on the starter. I still need my chipped key in the ignition to start it however. I've replaced everything ignition wise that deals with starting short of the ecu and the actual key cylinder.
Second issue is my reverse lights and the rear wiper/defroster have stopped working. I replaced the park/neutral sensor and adjusted the contact plate in the trans and gone over almost all the wires and all the conections to the rear end.
Third problem is my hvac system. I replaced the blower motor with a brand new one, resister with a new one, control unit with a new one, and again i've gone over almost all the wiring and have gone over all the conectors.
I need some ideas on what to do and try next. Also i was wondering if all these issues could be some how connected. Could i have possibly fryed my ecu somehow and that could be causing all this electrical asshatery.
HighOutputTj is offline
post #2 of 5 Old 11-05-2012, 07:36 PM
gmiller0737
1st Start with a proper wiring diagram for each system then either a Test Light or Volt Meter to diagnose the problems,The no start may be a problem the Neutral Safety Switch (Auto Transmission) Start There I know you said you replaced it but check a wiring diagram to see how the circiuts work and what value to expect at each wire during testing.
gmiller0737 is offline
post #3 of 5 Old 11-05-2012, 07:40 PM Thread Starter
HighOutputTj
I do have quite a few diagrams. And so far i havn't been able to track down anything
post #4 of 5 Old 11-05-2012, 08:18 PM
reisom
I just hopefully fixed my electrical demon after 2 months of tracking. I would start in the PDC area (fuse box under hood). Check all relays and fuses there. Then make sure all relays are getting good connections into their proper terminals. This was my problem. Starter relay wasnt getting good contact when seated in the PDC. Youre prob gonna have to get wiring schematics for each problem and start from one end and work your way thru until you find the prob. Hopefully you might get some help from RUBI4MYMRS. He knows what hes talking about when it comes to ignition probs. Have some patience, its frustrating, but worth it in the end.
reisom is offline
post #5 of 5 Old 11-05-2012, 10:36 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Check fuse #8 in the PDC in front of the battery. That supplied power to the starter relay & the ignition switch which with the key on powers fuses 5, 6, 7, & 8 in the fuse block behind the glove box.
Fuses:
5 is airbag
6 is rear wiper/washer
7 is back up lights & rear defrost
8 is HVAC blend door & blower relay control.
Pretty much everything you mention.
Rubi4MyMrs is offline
electrical issue , heat , ignition , reverse , starter
