Electrical Mystery - JeepForum.com
post #1 of 2 Old 02-26-2008, 09:34 AM Thread Starter
Heep
Heep's Avatar
Electrical Mystery
Everyone has had problems with their tail light guards, but I am determined to make mine work (I have the time and enjoy a good challenge).
Right now, the lights that work include tail lights, reverse lights, and third brake light. The brake lights do not work and I have no turn signals or hazards anywhere on the jeep.
I took the rubber washers off the bolts that came with the kit and even installed lock washers on the back side to insure a tight ground. All fuses in the fuse box are good. All fuses under the hood are good.
Anyone have any ideas?
Heep is offline
post #2 of 2 Old 02-26-2008, 11:06 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Jumper the ground via a wire between the frame and bulb socket base and see if they start working properly again. If they do, you still have a missing/weak ground problem. Personally I wouldn't run those tail light guards, they cost more to buy than the tail light housing they fit around. They certainly aren't strong enough to protect the tail lights if you were to back or slide into a big rock etc.
Jerry Bransford is offline
ECM, PCM, Electrical mystery svoss YJ Wrangler Technical Forum 23 03-16-2009 07:12 AM
mystery break in the electrical system Dsadinsky YJ Wrangler Technical Forum 15 07-27-2008 07:04 PM
Electrical mystery.... Arc YJ Wrangler Technical Forum 4 07-24-2005 08:34 PM
Help with electrical mystery K2Racing YJ Wrangler Technical Forum 5 01-25-2005 07:50 PM
Yj mystery..... 4x4punk YJ Wrangler Technical Forum 11 11-03-2004 07:42 AM
