Electrical is kicking my a$$!!!! - JeepForum.com
post #1 of 4 Old 03-30-2014, 02:22 PM Thread Starter
Chris_Skrep93
Okay, so here's my problem.....I have no dash lights or console lights, no running lights front or rear, no dinging when I leave the lights on and opem the door.
Here's what works...headlights, emergency lights, turn signals, stop lights, reverse lights, and interior lights via the dimmer switch.
No fuses were blown that I could see...replaced almost all of them just to be sure.
Any help is welcome! Not sure where this thread should go but hopefully someone finds it and has some ideas
Thanks,
Chris
Chris_Skrep93 is offline
post #2 of 4 Old 03-30-2014, 02:41 PM
durango-bob
2006 WK
Sounds like the headlight switch is not working right.
durango-bob is offline
post #3 of 4 Old 03-30-2014, 03:54 PM
crateampscal
yes id check that multifunction switch. if you have a factory service manual, it will show you how to test each terminal to make sure the switches are functioning properly.
crateampscal is offline
post #4 of 4 Old 03-31-2014, 02:42 PM
Jonny Jeep
Jonny Jeep's Avatar
Did you check fuse 1 behind the glove box. That supplies power to the headlamp switch for marker lights and dash illumination.
Jonny Jeep is offline
electrical , tj , wiring
