electrical issues with lifted TJ - JeepForum.com
post #1 of 4 Old 11-03-2008, 10:46 AM Thread Starter
FX}
I recently put a 2" suspension lift and 1.25" body lift on my 03 TJ. I am now experiencing some kind of electrical problem. When I first start the Jeep it barely starts and then will not idle on its own without me giving it gas. Although, sometimes it will work perfectly. It is acting like it is under a heavy load. I had Autozone check the battery and alternator. Both are good. Could it be a ground wire? Are there any grounds that need extended during a body lift? If not that there must be a short somewhere. Maybe in the starter? The Jeep was running flawlessly before the lift. Anyone run into anything like this?
Thanks,
Dan
FX} is offline
post #2 of 4 Old 11-03-2008, 02:17 PM Thread Starter
FX}
no one has encountered anything like this?
FX} is offline
post #3 of 4 Old 11-03-2008, 03:14 PM
BlazinJack
sounds like you may have unplugged a sensor or disturbed a ground strap. maybe the crank position sensor on the bellhousing or the ground strap from engine to firewall. or maybe one of the plugs right to the computer on the firewall. also check your fuel lines for disruption, this may be another problem.
BlazinJack is offline
post #4 of 4 Old 11-04-2008, 04:29 PM Thread Starter
FX}
Got it. Thanks
FX} is offline
Some Electrical Issues dascione TJ Wrangler Technical Forum 2 11-12-2009 01:00 PM
electrical issues Nutter78 YJ Wrangler Technical Forum 0 05-05-2009 07:56 AM
New problem, still dealing with electrical issues. UPDATED, STILL HAVE ISSUES!!!!! rustywrangler YJ Wrangler Technical Forum 34 02-17-2009 04:51 PM
Help.......electrical issues computerguy YJ Wrangler Technical Forum 5 05-05-2008 10:10 PM
Lifted JK with Rock Rail Issues! blkngld JK Wrangler Technical Forum 29 11-11-2006 12:27 AM
