Electrical issue with TJ oil and water guages - JeepForum.com
post #1 of 1 Old 08-06-2010, 09:59 AM Thread Starter
weston
I have a 99 wrangler with auto trans and 4.0 engine. The water temp and oil preasure gauges will sometimes work and sometimes not. It may be one or the other or both at the same time. Is there a way to fix this or can I put aftermarket gauges on it? Also, when they are not working a light in the dash says check gauges. Thanks for any help.
weston is offline
gauges , electrical , electric , oil , water , temp , temperature , tj , wrangler , error
Electrical, guages and dome light out, help! michfab TJ Wrangler Technical Forum 13 09-23-2009 02:26 AM
Electrical issue stoneyredneck TJ Wrangler Technical Forum 6 07-23-2008 02:28 PM
electrical issue gamble71 TJ Wrangler Technical Forum 4 04-10-2007 11:11 AM
Electrical ribbon for dash guages Redskinswin YJ Wrangler Technical Forum 16 03-20-2007 06:12 PM
Electrical issue?? pwoens YJ Wrangler Technical Forum 2 09-16-2005 12:43 AM
