Electrical gremlins or wife on crack... - JeepForum.com
post #1 of 31 Old 05-21-2013, 11:43 AM Thread Starter
NotURMailman
Not really a question:
Got the wife an '05 Rubicon for Mother's Day.
Everything was great.
Sunday night she calls me from the road and says her wipers and 12V auxiliary power plug don't work.
I let her take my 3500 to work on Monday (can you say nervous wreck?).
I get home and hop in her Jeep and everything works. The wipers, the outlet, everything.
I did take the cover off of the column and remove and re-seat the plug ont tne MFS, but that was after everything worked for me and it seemed to be well seated.
I think she may have just wanted to drive my truck...
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #2 of 31 Old 05-21-2013, 11:46 AM
TheBoogieman
Deeply Disturbed
TheBoogieman's Avatar
Those wife mods are very tricky.
"Getting advice on the best shocks is like getting advice on the best woman. Everyone has their opinions and ALL are disappointed after the break-in period and want to look for better alternatives."
TheBoogieman is offline
post #3 of 31 Old 05-21-2013, 12:37 PM Thread Starter
NotURMailman
Indeed...
And mine appears to be malfunctioning!
post #4 of 31 Old 05-21-2013, 01:23 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
Why is she out of the kitchen?
RnEmOvr is offline
post #5 of 31 Old 05-21-2013, 01:26 PM Thread Starter
NotURMailman
I would duck if I were you!
post #6 of 31 Old 05-21-2013, 01:30 PM
bbradUSMC
Well everyone knows why women's feet are smaller.
bbradUSMC is offline
post #7 of 31 Old 05-21-2013, 01:36 PM
RnEmOvr
RnEmOvr's Avatar
I'll give her the benifit of a doubt she was at store getting more food.
Thus why she should have never left the kitchen
/derail
MFS is probably going out or had water in it.
RnEmOvr is offline
post #8 of 31 Old 05-21-2013, 01:43 PM
prew
Better hang some bells for those gremlins
prew is offline
post #9 of 31 Old 05-21-2013, 01:43 PM
jeepinhokie
which 12v plug was she trying? switched or unswitched? left is switched and right is unswitched.
I ask b/c i lost power to my unswitched outlet and plug, the switched one works just fine.
HOKIES UNITED!
jeepinhokie is offline
post #10 of 31 Old 05-21-2013, 05:05 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
The wipers & switched power outlet are on fuses 18 & 17 in the fuse block & are powered by the same contacts in the ignition switch. Unless there is a bad connection at the switch connector on the 12g red wire (near the middle of the connector), the ignition switch is probably going bad. If it happens again have her wiggle the key but you will likely end up having to replace it.
Rubi4MyMrs is offline
post #11 of 31 Old 05-23-2013, 09:54 AM Thread Starter
NotURMailman
I don't know what was up with the 12V plug. But I figured out that she was trying to turn on the wipers by turning the end of the stock (like you do to adjust the intermittent wiper delay) instead of clicking it up
post #12 of 31 Old 05-23-2013, 11:55 AM
bbradUSMC
Should have kept her in the kitchen.
post #13 of 31 Old 06-20-2013, 07:23 AM Thread Starter
NotURMailman
OK, so...
Maybe she's not completely crazy.
I was driving it this morning and the speedometer all of a sudden just quit.
Then the check engine light came on.
Then some idiot pulled out in front of me and when I hit the horn it didn't work.
Then my GPS came up saying I had unplugged it, like power to the 12V accessory outlet just died.
I pulled over to get a drink at the gas station.
I pulled the codes, P0501 for VSS as expected.
When I came out of the store and got back in it everything worked fine.
Grr...
I'm thinking multiple issues.
Annoying!
post #14 of 31 Old 06-20-2013, 07:25 AM
RnEmOvr
RnEmOvr's Avatar
I short in the harness could cause that. On the main engine harness there is one 12v wire that feeds about 5-10 things. If that wire messed up it would cause a bunch of issues.
RnEmOvr is offline
post #15 of 31 Old 06-20-2013, 07:40 AM Thread Starter
NotURMailman
I thought about that, but the plug, horn, and speedo were the only things not working.
I am really starting to miss my Mitchell on Demand log in for schematics...
Oh well, I'll figure it out. Just going to be annoying.
All internittent electrical problems are annoying!
